Help with shielding starter cable from headers #3163559
07/27/23 07:46 AM
07/27/23 07:46 AM
San Angelo, Texas, U.S.A.
1968RR Offline OP
1968RR  Offline OP
I recently had the starter cable on my '68 Road Runner burn up and short on the headers. I did my best to route the new cable in such a way that it won't touch the headers, but there are still a couple of places near the starter where the cable is only about 1/4" away from the header tube (and the engine shakes quite a bit when running). I also used a heat sheath to cover the cable, but I don't have too much faith that it'll help long-term. Should I try something like header wrap to help insulate the exhaust near the cable? Any other suggestions?
Thanks in advance for any help.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Help with shielding starter cable from headers [Re: 1968RR] #3163569
07/27/23 09:04 AM
07/27/23 09:04 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Do you have a pick-a-part salvage yard near you? Many late model vehicles have excellent heat shields and insulation on everything from A/C lines to fluid lines. All styles and sizes. I have boxes of them that I keep to choose from when myself or one of my buddies run into this problem. I like to use the insulated tubes for starter wires. The stuff is dirt cheap, too. Just a little time and effort to find and pull 'em.
twocents
Master, again and still
Re: Help with shielding starter cable from headers [Re: DaveRS23] #3163572
07/27/23 09:25 AM
07/27/23 09:25 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That heat sleeve in the link is probably not adequate.
Use "fire sleeve", which is insulated tubing with a silicone cover - typically silver or reddish color.
I've run it next to headers on race cars and it has held up.
Re: Help with shielding starter cable from headers [Re: topside] #3163574
07/27/23 09:35 AM
07/27/23 09:35 AM
1968RR Offline OP
1968RR  Offline OP
Thanks for the suggestions!
Re: Help with shielding starter cable from headers [Re: 1968RR] #3163630
07/27/23 12:45 PM
07/27/23 12:45 PM
Cab_Burge Online work
Cab_Burge  Online Work
Get a longer cable and feed it from the top above the starter to get it away from the headers scope wrench up
Re: Help with shielding starter cable from headers [Re: Cab_Burge] #3163761
07/27/23 10:21 PM
07/27/23 10:21 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
Yep.
America First!
