Re: Old Gasoline question
[Re: hamerg]
#3163726
07/27/23 07:32 PM
07/27/23 07:32 PM
Posts: 21,528 N.E. OHIO, USA
A12
N.E. OHIO, USA
[quote ]I parked my 'cuda with a full tank of gas in the fall 9-YEARS AGO and then life got in the way![/quote] EDIT missed the 9 YEARS thought I read 9 MONTHS. 9 years is a whole different issue and as said get rid of as much as you can before even trying to start it. Wonder what your carb is like at 9-years??? Should be easier than a '92 Lebaron to go through the filler tube and drain as much as you can.
[Re: A12]
#3163730
07/27/23 07:57 PM
07/27/23 07:57 PM
Posts: 10,748 North Dakota
6PakBee
North Dakota
Get rid of half the tank, a full can of SeaFoam and a refill with the best premium you can find and you should be all right. Just make sure when you get it fired up, run it long enough (at least half an hour) to get the SeaFoam into the engine. A stuck intake valve from bad gas is a real bummer.
[Re: CrazyD]
#3163845
07/28/23 11:16 AM
07/28/23 11:16 AM
Posts: 2,922 Calgary, Alberta Canada
a12rag
As most said, I would want to drain as much out, remove the fuel line from the fuel pump, and use air to blow the fuel line from tank to pump clear (maybe put some cleaner material in the line first) . . . all that being said, I had a buddy that had his 71 fury, sitting for 8 years - not sure how much fuel in tank, but he just put battery in car, with a high amp battery charger on it, and cranked and cranked it till it started . . . actually ran fine ! I was amazed !! . . . seeing how you had tank FULL, that probably would help with keeping water out . . but never know . . . I would not want to chance it, and certainly would drain and clean fuel system.
[Re: BSB67]
#3163857
07/28/23 11:54 AM
07/28/23 11:54 AM
Posts: 11,645 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Drain it. Take the tank out and clean it well. Flush the system. Check the hoses for dry rot. Carb and fuel pump are also suspect. Don't pump gas into the crankcase, flood the engine or leak gas all over the intake..
9 month old pump gas is weed killer. 9 year old gas, even more so. Don't even try to get it to start on that.
Or you can go get a can of starting fluid, detonate it to life, and hope for the best.
[Re: TJP]
#3163917
07/28/23 02:54 PM
07/28/23 02:54 PM
Posts: 10,619 Freeport IL USA
poorboy
Freeport IL USA
well, it is possible that 9 year old gas is better then the stuff they are selling at the pump these days. Really!
The sniff test would be the starting point, it either still smells like gas, or it doesn't. If it smells like varnish, get rid of it. If it smalls like gas, I would be tempted to get a little out of the tank (not much) and put it onto a cement driveway, away from everything, and throw a lit match into it and see if it would burn. If it burns, I might be tempted to use it. If it doesn't burn, it all goes away. Drain the tank, blow out the fuel lines, and empty the carb and blow out the passages. Start with fresh gas.
If you are unsure after reading all the comments here, drain the tank, blow out the fuel lines, empty the carb & blow out all the passages. Its probably not worth taking the chance it still might be OK.
[Re: NITROUSN]
#3163978
07/28/23 06:39 PM
07/28/23 06:39 PM
Posts: 3,089 Michigan
A727Tflite
How do you all get rid of old leaded race gas?
I do not want to use it in modern cars or yard equipment. I use it burning brush. Talk about coincidence. I just did the same, gasoline that was 16 years old from an old camper I had to scrap. They wouldn’t accept it with a gas tank so I drained it. Poured it over my burn pile - lit it and it burned like a Hindu Funeral.
[Re: 340Cuda]
#3163980
07/28/23 07:02 PM
07/28/23 07:02 PM
Posts: 28,604 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I do not want to use it in modern cars or yard equipment. The VP 110 with lead i had in a sealed metal 15 gallon drum was like new ran fine in mowers and generator was from 2004.
[Re: 340Cuda]
#3164001
07/28/23 08:51 PM
07/28/23 08:51 PM
poorboy
Freeport IL USA
I do not want to use it in modern cars or yard equipment. I would not be concerned about using it in modern yard equipment. The lead won't bother the yard equipment, but if you are that concerned, mix it with modern gas. Better yet, one might check a few local old car clubs, some of those guys might be really happy to get their hands on real leaded high octane race gas. Guys at a local oval track might like some too, and maybe other drag racers?
