Brake question #316340
05/12/09 09:07 PM
05/12/09 09:07 PM
Versailles Oh
Beefman1 Offline OP
Beefman1  Offline OP
Versailles Oh
Ive got a 92 Plymouth sundance that had the right front brake caliper sticking.Replaced the caliper test drove it and have the same problem the brake gets hot and grabs and smokes.Could there be a restriction in the brake line causing this?Or could the master cylinder be the problem?
Re: Brake question [Re: Beefman1] #316341
05/12/09 09:18 PM
05/12/09 09:18 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Flex hose
Re: Brake question [Re: Beefman1] #316342
05/12/09 09:25 PM
05/12/09 09:25 PM
PA
70Duster Offline
70Duster  Offline
PA
Wild Bill is right...replace the hose.
Re: Brake question [Re: 70Duster] #316343
05/12/09 09:29 PM
05/12/09 09:29 PM
Versailles Oh
Beefman1 Offline OP
Beefman1  Offline OP
Versailles Oh
Flex hose was my first guess thanks guys.
Re: Brake question [Re: Beefman1] #316344
05/12/09 09:33 PM
05/12/09 09:33 PM
M/C no, flex hose possibly. I would think a bad new caliper(does happen) or something in the pad area thats hanging things up & next time it locks up I'd pull the wheel & see if anything looks like it is binding the pad(other than the caliper piston) then without moving anything loosen the brake line & see if it releases the pad
Re: Brake question [Re: RapidRobert] #316345
05/14/09 08:18 PM
05/14/09 08:18 PM
Versailles Oh
Beefman1 Offline OP
Beefman1  Offline OP
Versailles Oh
Changed the flex hose and that was the problem,works great.the original caliper was bad to begin with and I wasnt expecting anymore problems but hey you never know.Well shes fixed now so alls well.
Re: Brake question [Re: Beefman1] #316346
05/14/09 09:04 PM
05/14/09 09:04 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
