Crankcase Pressure/Evac System/Stage 6 Heads #3156119
07/02/23 07:42 AM
07/02/23 07:42 AM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
Happy 4th everyone! I got thru the transmission puke issue and made it out to a test and tune only to run into my next gremlin. So picked up this 500 ci motor complete as a stroker and had machine shop go thru it to lower compression. In that process bored it over a little more and did 10/10 on rods and mains so motor is fresh. Rings were file fit per instructions with the pistons by the machine shop and this guy knows what he's doing, but I haven't done a leak down check or anything like that yet. Motor was being run with evac canisters on both valve covers, but I did change them out for new ones. Welded in the bungs into my collectors at the angle and depth that are on another pair of headers I have. But getting oil blowing out of my sheet metal valley pan that was with the motor when I bought it. This is only happening on a run, mainly. Originally was only from the rear, I put a valley pan bar on the rear. Made 3 passes and by third pass had to quit for the night as oil came out the front and the rear. So looking for a remedy on this. I do have 2 other sets of canisters I can try. Also curious what other guys are using for valley pan for Stage 6 heads. I think the spacer makes things difficult for any other valley pan from my thoughts. What things can I check with the canisters or anything else to figure this out before going with a vacuum pump?
Re: Crankcase Pressure/Evac System/Stage 6 Heads [Re: Mopar.70] #3156122
07/02/23 07:54 AM
07/02/23 07:54 AM
Andrews,In. U.S.of A.
67_Satellite Offline
Adding the reinforcement plates across the 3 hold down bolts on each end might stiffen it up enough to stop the leakage.
Re: Crankcase Pressure/Evac System/Stage 6 Heads [Re: 67_Satellite] #3156126
07/02/23 08:12 AM
07/02/23 08:12 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Are you using any type of sealer at the ends? I also would use the plates. Take off reseal put plates on and try again.
JAKES AUTOMOTIVE
Re: Crankcase Pressure/Evac System/Stage 6 Heads [Re: JAKE68] #3156127
07/02/23 08:34 AM
07/02/23 08:34 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
On my 383/496 motor with Stage VI heads, I use the pan evac from Moroso only. The diaphragm inside the breathers and check valve can get rusty and not work properly, you can put a vacuum gauge on the hose at the valve cover and check the amount of vacuum its actually pulling. I use the aluminum valley pan from Hughe's but have to trim to fit along with the front and rear support brackets, I do use Permatex Right stuff to seal all four contact area's, never had a leak making mid 9 seconds passes. I use a Edelbrock RB 440 intake with no spacers and that buys more room to use the aluminum valley pan.
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Crankcase Pressure/Evac System/Stage 6 Heads [Re: Wicked49670dart] #3156187
07/02/23 12:00 PM
07/02/23 12:00 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I used the MP intake so no “pan” was required on our old RB/498 StgVI mill. It seemed fairly common for it to leak some oil on a pass, until its last freshen when we used Total Seal rings. Always used the Moroso breathers. Looking in the headers it appeared from some residue that it was pulling vapor from the crank case.
Re: Crankcase Pressure/Evac System/Stage 6 Heads [Re: Mopar.70] #3156266
07/02/23 03:55 PM
07/02/23 03:55 PM
A good vacuum pump is your friend, 30 HP + gain above 6000 RPM and the oil stays clean a lot, lot longer twocents scope wrench up
Re: Crankcase Pressure/Evac System/Stage 6 Heads [Re: JAKE68] #3156439
07/03/23 09:27 AM
07/03/23 09:27 AM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Crankcase Pressure/Evac System/Stage 6 Heads [Re: an8sec70cuda] #3156523
07/03/23 12:46 PM
07/03/23 12:46 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
Yea, I had sealed the ends with the high pressure grey RTV that i used on my girdle. It blew thru on the back side first, did some silicone on the lip afterwards and added a valley tray bar, then it ended up coming out the front as well. They need resealed, but only after I figure out what the fix is, either bad check valves which are new at the headers, bad canisters on the valve covers which are new too. Or. . . scrap it all and do a vacuum pump. It's just that if I can fix it for $50 bucks, rather do that than a grand on the vacuum pump.
Re: Crankcase Pressure**Update Vacuum Pump** [Re: Mopar.70] #3163216
07/25/23 09:47 PM
07/25/23 09:47 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
So I took the plunge and bought a vacuum pump kit from GZ Motorsports. Will be starting the install on it this weekend. Couple questions that come to mind, and no I haven't read all the paper work yet. It could be in there, but wanted to put this out to the group while it's on my mind. Looks like the pump is set for 21. What "pressure" does everyone else run there's at? Read somewhere to much can pull oil from the bearings. Also, do any of you mount a permanent gauge to monitor this? Big block chevy buddy tells me his is set to 15, and has a port in the fuel pump block off plate. Just trying to gather all info (and parts) ahead of time. Thanks!!!
Re: Crankcase Pressure**Update Vacuum Pump** [Re: Mopar.70] #3163257
07/26/23 01:44 AM
07/26/23 01:44 AM
Which GZ pump did you buy?
The pump may or may not be able to pull the vacuum you want, that depends on how good you have your motor sealed up on the rings and seals and gaskets and how tight you can get the drive belt, been there learned that shruggy
Good luck, do NOT put the vacuum fittings in the fuel pump block off plate tsk You will fill the puke tank in one or two runs shock tsk
My motors ended up liking the fitting in the top of the cast aluminum valve covers with no breather caps on them, I ended up buying some of the cast polished aluminum valve covers from either Speedmaster or Pro Form from Summit Racing that had no holes in them and drill them with a large Unibit bit to fit the rubber grommets I needed when I was using a PCV only and ended up buying another pair and bought a screw on two piece fitting that I could use a AN hose from the pump to that fitting only and did not put any other holes in them, I would disconnect that fitting when I would change oil and use a small funnel to pour the oil into the motor through that fitting wrench up
I didn't mount my pump on my front motor plate so I could tighten it or loosen it up realcrazy Never again tsk blush The most vacuum I could pull was right at 5.5 inches no matter what I did other than remounting the pump better, that was with the GZ enhanced pump, their best one whiney
I have bought two Moroso vacuum pumps since then, one three vane and one four vane, I'm hoping they both work better, I'll really focus on sealing the motors better and mounting the pumps so they can be adjusted to tighten the belts really tight luck grin
Good luck on your deal up
Re: Crankcase Pressure**Update Vacuum Pump** [Re: Cab_Burge] #3163264
07/26/23 07:14 AM
07/26/23 07:14 AM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
Cab, I bought the super pro pump. My motor is sealed up very well, other than this pesky deal at the sheet metal valley pan. The port I meant in the fuel pump block off plate is intended to leave a gauge, or hook up a gauge too. I will put the main line port in the top of the valve cover.
Re: Crankcase Pressure**Update Vacuum Pump** [Re: Mopar.70] #3163272
07/26/23 07:54 AM
07/26/23 07:54 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
My GZ pump pulls about 19-12hg. It has a fitting in the valley plate for 1/4" pushlock to the vacuum gauge. It could be in the valve cover as well. My fitting is in the front wall of the valve cover close to the intake side. pulls about 3-4oz of oil in 20-25 passes.
Doug
Re: Crankcase Pressure**Update Vacuum Pump** [Re: dvw] #3163279
07/26/23 08:27 AM
07/26/23 08:27 AM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
Do you have any kind of baffle plate in the valve cover where the port is on the insdie? Or is it straight open into that area?
Re: Crankcase Pressure**Update Vacuum Pump** [Re: Mopar.70] #3163313
07/26/23 10:26 AM
07/26/23 10:26 AM
I had a baffle welded under my fittings on my cast aluminum valve covers that broke the welds off after a while, I don't know exactly when it did that, I found it when I went to check the valve lash and remove it and saw no difference in performance or oil in the catch can after removing it work My message I don't think you really need one up
Re: Crankcase Pressure**Update Vacuum Pump** [Re: Cab_Burge] #3163461
07/26/23 05:58 PM
07/26/23 05:58 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I run a Moroso Advanced 4 Vane vac pump. No issues with it. 17-19". Only adds to the over flow with only a couple of oz after many passes and hundreds of street miles. I still drain it after ever pass just to be sure.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Crankcase Pressure**Update Vacuum Pump** [Re: 6PKRTSE] #3165705
08/05/23 09:07 AM
08/05/23 09:07 AM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
Well, the pump worked better than it's supposed to. Factory set for 21, it pulled that and more and sucked the valley pan down. GZ said factory set for 21 it would never pull that much on my motor, guess I have it sealed up pretty good. This was on the initial run to test and set it. So, gotta take the manifold back off, try to figure out what I can do for a valley pan and re set it. Plan for the next time is to back off the regulator and sneak up on it. These stage 6 heads seem to limit me on what I can do for a valley pan. No racing this weekend. . .
Re: Crankcase Pressure**Update Vacuum Pump** [Re: Mopar.70] #3165717
08/05/23 10:45 AM
08/05/23 10:45 AM
PA
moparacer Offline
moparacer  Offline
PA
You should never start with it maxed out and work down. Always start low and work up. I can't believe they didn't tell you to do it that way. eek
Too much vacuum, supposedly pulls oil from the wrist pins on some setups. I pull 10 on mine. Went to 15 seen no improvement in ET. Went back to 10 and left it there.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Crankcase Pressure**Update Vacuum Pump** [Re: Mopar.70] #3165866
08/05/23 10:15 PM
08/05/23 10:15 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Just open. No baffle.
Doug
