manual or power steering ?
returning to center requires positive caster, regardless of the steering box used. [just like stumpy said]
visualize a shopping wheel cart's front wheels. most times, the "wobbly" ones you push have had the front steer wheels crashed into many objects, therefore making them out of kilter. in other words, the caster angle of the pivot point of the wheels has been bent/broken/repaired wrong, etc. causing the wheels to want to go in a direction other than straight ahead.
manual box vehicles need a zero to a negative couple of degrees caster to be able to comfortably turn at slow speeds, plus a garbage can lid sized steering wheel.
power box vehicles can use a bunch of positive caster [5-6 degrees or more, depending on the application and driver preference] to want to "stay straight at speed" and have the ability to want to return to center after a turn, as well as use a smaller, more comfortable feeling, diameter steering wheel, because of the hydraulic assist the pump provides.
the one downside of lots of positive caster, is the "jacking effect" it causes at extreme lock. depending on the camber curve, and the toe curve, this can cause some handling issues in autocross events, or just feel weird to the casual driver.
