secret of ancient Roman concrete mix
#3161821
07/22/23 05:25 AM
07/22/23 05:25 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
https://www.sciencealert.com/we-finally-know-why-ancient-roman-concrete-stood-the-test-of-timesample quote One of the questions in mind was the nature of the lime used. The standard understanding of pozzolanic concrete is that it uses slaked lime. First, limestone is heated at high temperatures to produce a highly reactive caustic powder called quicklime, or calcium oxide. Mixing quicklime with water produces slaked lime, or calcium hydroxide: a slightly less reactive, less caustic paste. According to theory, it was this slaked lime that ancient Romans mixed with the pozzolana. Based on the team's analysis, the lime clasts in their samples are not consistent with this method. Rather, Roman concrete was probably made by mixing the quicklime directly with the pozzolana and water at extremely high temperatures, by itself or in addition to slaked lime, a process the team calls "hot mixing" that results in the lime clasts. "The benefits of hot mixing are twofold," Masic said. "First, when the overall concrete is heated to high temperatures, it allows chemistries that are not possible if you only used slaked lime, producing high-temperature-associated compounds that would not otherwise form. Second, this increased temperature significantly reduces curing and setting times since all the reactions are accelerated, allowing for much faster construction." And it has another benefit: The lime clasts give the concrete remarkable self-healing abilities. When cracks form in the concrete, they preferentially travel to the lime clasts, which have a higher surface area than other particles in the matrix. When water gets into the crack, it reacts with the lime to form a solution rich in calcium that dries and hardens as calcium carbonate, gluing the crack back together and preventing it from spreading further. end quote
Re: secret of ancient Roman concrete mix
[Re: cudaman1969]
#3162030
07/22/23 03:53 PM
07/22/23 03:53 PM
Posts: 6,240 nowhere
Sniper
nowhere
What procedure did they use to get it hot since all they had was a fire and a pot? Was it made in 5 gallon batches? Same, or similar, to how they made ceramics. You know, pots and such? In a kiln
[Re: Neil]
#3162333
07/23/23 12:43 PM
07/23/23 12:43 PM
Posts: 9,454 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
I did a coupe pre rev war home restorations which involved mixing lime with the plaster and horse hair. Not the most fun.
STOP POTATO HATE!
[Re: PhillyRag]
#3162581
07/23/23 10:32 PM
07/23/23 10:32 PM
Posts: 8,250 fredericksburg,va
cudaman1969
fredericksburg,va
Interesting how the European societies went to he11 after roman faded. No organization with brain dead leaders and drug sons.
[Re: 360view]
#3163053
07/25/23 12:28 PM
07/25/23 12:28 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Another learning example IMO of a flaw in the Proverbial "Common sense" mantra ie "everyone knows concrete must be mixed real well"? thinking?
[Re: Neil]
#3163068
07/25/23 01:03 PM
07/25/23 01:03 PM
Posts: 10,022 MN
JERICOGTX
MN
Those old structures also don't use steel reinforcement either. Our bridges and highway overpasses fail from the inside out due to rebar corrosion beneath the surface. They did a lot with what they had available to them regardless. Look at the Atlantic Wall from WWII. It's falling apart from exactly what you stated. Water, freezing, and corrosion.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3163147
07/25/23 04:52 PM
07/25/23 04:52 PM
jcc
Bitopia
Those old structures also don't use steel reinforcement either. Our bridges and highway overpasses fail from the inside out due to rebar corrosion beneath the surface. They did a lot with what they had available to them regardless. Look at the Atlantic Wall from WWII. It's falling apart from exactly what you stated. Water, freezing, and corrosion. That is not a great example in this context IMO. The Atlantic Wall was never intended to last more than a decade I suspect. AH frowned on the use of concrete for his most important structures, he wanted those to last a thousand years, which concrete at that time would hardly last 100 years, but stone was up to the task, irrespective of rebar failing/corrosion/expansion. This nation has a number of TVA dams built prewar in a hurry that are way past their design life for concrete and must be dealt with soon. Personally, I am most impressed with the imported concrete used in the Florida Keys bridge system to Key West, that has withstood countless hurricanes, extreme temps, constant saltwater exposure and decades of traffic, and is still standing with zero Maintenace for over forty after being built over 110 years ago privately.
[Re: jcc]
#3163286
07/26/23 09:12 AM
07/26/23 09:12 AM
Posts: 8,162 USA
360view
USA
I am most impressed with the imported concrete used in the Florida Keys bridge system to Key West, that has withstood countless hurricanes, extreme temps, constant saltwater exposure and decades of traffic, and is still standing with zero Maintenace for over forty after being built over 110 years ago privately. old piers originally poured in year 1911
[Re: 360view]
#3163291
07/26/23 09:20 AM
07/26/23 09:20 AM
Posts: 8,162 USA
360view
USA
[Re: 360view]
#3163293
07/26/23 09:42 AM
07/26/23 09:42 AM
jcc
Bitopia
Nice pics btw, but those pics are of a maintained section of bridge to Pigeon Key still used today for limited traffic, there are countless miles of other concrete bridges in the Keys also still erect and maybe still useful if they had the steel structures maintained.
[Re: 360view]
#3163294
07/26/23 09:44 AM
07/26/23 09:44 AM
cudaman1969
fredericksburg,va
BUT just like all products made today, I you build it to last they will be out of the perpetual work. Ah, Dentist, lawyers, Doctors, tire companies, most anything that wants their doors stay open.
