Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires #3160349
07/17/23 06:43 PM
07/17/23 06:43 PM
Bowling Green KY / Nashville, ...
300by500 Offline OP
300by500  Offline OP
Getting ready to order an S60 rear end for the mini-tubbed 69 Barracuda.
From what I’ve seen so far online, looks like a 335/50/15 is the street tire most people are running. But after doing some measuring, I think I can fit something bigger if I could find wheels with different backspacing?
I was just wondering (before ordering a rear end) what other options might be available.
Thanks, Moparts!
Re: Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires [Re: 300by500] #3160390
07/17/23 08:49 PM
07/17/23 08:49 PM
Call or contact the wheel companies you like and see what they offer scope up
I would recommend getting the wheels you want made and use them tuck up in the wheel wells with the tires you want to run mounted so you can get the proper width (axles to axle widths) rear down to the 1/8 inch correctly up scope wrench twocents
Re: Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires [Re: Cab_Burge] #3160401
07/17/23 09:56 PM
07/17/23 09:56 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
iagree
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires [Re: BloFish] #3160419
07/17/23 10:42 PM
07/17/23 10:42 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
That is how I built my car. I built it around the wheels and tires.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires [Re: 6PKRTSE] #3160428
07/17/23 11:26 PM
07/17/23 11:26 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
^^^ Yup, the guys I know that build racecars start with wheels & tires, then the rearend width.
You can get different axle widths, but not necessarily wheel widths & backspacing.
Obviously rear suspension, frame rail location, and tub size figure in there too.
Might be a good idea to look at SS/AH cars for reference.
Re: Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires [Re: 300by500] #3160438
07/18/23 01:03 AM
07/18/23 01:03 AM
AndyF Offline
AndyF  Offline
Figure out what tire size you want and then look for wheels that are available without costing a fortune and then see how those fit in the car. Once you know the ride height and the wheel placement in the tub then you can order the axle. Ordering the axle is one of the last things to do, not the first. Custom rear end housings only take a phone call. Figuring out which rim and tire combo to use and where to put them can take a lot longer. I spent a lot of time under my Duster before I ordered parts. I wanted a certain size tire located in the right spot. It takes a fair amount of time and effort to make it happen.
Re: Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires [Re: AndyF] #3160444
07/18/23 06:14 AM
07/18/23 06:14 AM
west palm beach, florida
modelmakerinc Offline
iagree Buy wheel and tire combo that fits and looks like you want, then measure with them posed in their position. Dont forget to add +/- 1/2" to the measurement to assume rotor or drum thickness. If you need to be somewhat conscious of budget try to find some that are mounted already and may be a great deal. surf the sale ads beer
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires [Re: modelmakerinc] #3160478
07/18/23 10:45 AM
07/18/23 10:45 AM
AndyF Offline
AndyF  Offline
One trick I learned is to order the rear end a little narrower than needed. That way you can use thin wheel spacers to push the wheel out to the edge of the fender for looks. I'll remove the spacers when I'm going to drive the car a lot, but if I'm going to a car show I'll put the spacers in so the tires are pushed all the way to the edge. Usually all you need is 1/2 per side to give you extra clearance for driving.
Re: Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires [Re: AndyF] #3160636
07/18/23 04:14 PM
07/18/23 04:14 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
What spacers do you use Andy?
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires [Re: BloFish] #3160674
07/18/23 06:34 PM
07/18/23 06:34 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I'll take a SWAG that Andy makes his own spacers exactly the size he wants.
Re: Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires [Re: GomangoCuda] #3160686
07/18/23 07:08 PM
07/18/23 07:08 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires [Re: BloFish] #3160783
07/18/23 10:26 PM
07/18/23 10:26 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
really a lot of things to consider here, what ar the goals for the car?? i ask because if you want a double beadlock sometime in the future, you really want as little back space as possible. It really helps to mount the tires with 2" or so backspacing.
Anyway as mentioned, buy the wheels and tires you want or borrow , situate them under the car and measure between them. Also as mentioned make sure you subtract 1/4 to 1/2 for brake spacing. Also as mentioned , its easier to add a 1/8 or 1/4 wheel spacer than to re shorten the housing !!
When you have your final measurement , call Strange or whoever and thats your "width" it is absolutely the best way to do it. I did my car (1973 dart ) this way 12" rim double beadlock with 275 radials. And my sons duster 12" rim with 315 radials
689E847C-2D07-4C53-806E-9CD710E7F406.jpeg0055F1AB-C7C6-492E-9924-A129EE744652.jpeg08F14DC9-1F87-437B-808C-94FF86F4DF41.jpeg
....BAD A$$ STREET CAR.....
Re: Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires [Re: n20mstr] #3162556
07/23/23 09:15 PM
07/23/23 09:15 PM
300by500 Offline OP
300by500  Offline OP
Lots of good info here!
Thanks, everybody!
Re: Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires [Re: 300by500] #3162641
07/24/23 09:00 AM
07/24/23 09:00 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
On race cars, spacers are a no no
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Mini-tubbed 67-69 Barracuda Fastbacks - what wheels / tires [Re: bigdad] #3163031
07/25/23 11:30 AM
07/25/23 11:30 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Mine is mini-tubbed to the frame rails, 15"X10" rim - 7" BS, regular A-body width Dana 60 in a 1969 'Cuda, on a pair of 325/50-15 M/T street drag radials.
