Re: 16V POWERMASTER [Re: sogtx] #316028
05/15/09 09:16 PM
05/15/09 09:16 PM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
ok , i think theres more than plopping this 16 v battery in ..
the voltage regulator will limit the voltage to the coil and instruments so the 16 volt will
only feed the starter and coil in start position ?
I don't run that stuff ..I tried that years ago and I had poor luck so I use a charger between rounds with a battery/charger set up in the pits to charge/ run my fans,pumps, etc.
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 16V POWERMASTER [Re: bigdad] #316029
05/16/09 03:52 PM
05/16/09 03:52 PM
Central,Ohio
FASTFISH420 Offline OP
Central,Ohio
Well I broke down and bought the Powermaster 16 volt D1000 battery and charger today...Installed it and man that thing cranks like a Pro Stocker..
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: 16V POWERMASTER [Re: FASTFISH420] #316030
05/16/09 07:03 PM
05/16/09 07:03 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
We run the poor mans 16v, 2 8v golf cart batts in series , no alt and dont charge between rounds, the batts cost around 120 each and are heavy as hell < wanted more weight aft anyhow> charge them up full the day before we run with no problems.car starts better , runs cooler and no problems seeing the gauges at night
Re: 16V POWERMASTER [Re: emarine01] #316031
05/16/09 10:16 PM
05/16/09 10:16 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
Being an even poorer SS guy, we also use the 2 8V group 24 batts, wired in series, except we buy the "tractor" batteries, about $65 each, the 2 batts together weigh just slightly more than one 16V Turbostart style.
Be a Rebel- Break the Laws of Physics!
Re: 16V POWERMASTER [Re: mbogina] #316032
05/19/09 05:20 PM
05/19/09 05:20 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
http://www.kennebell.net/accessories/boostapump/boostapump.htm
I ordered on of these Kenne Belle Boosta Pump systems ...
At least I wont have to charge the battery at the track
Maybe this is a good idea
Re: 16V POWERMASTER [Re: sogtx] #316033
05/19/09 05:41 PM
05/19/09 05:41 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I had a 16 volt Turbo Start the only thing good about it was the charger. It works fine on the 16 Volt Rock battery. The 16V Rock battery has twice if not more power cranking the engine.
I do not sell either battery,just trying to help everyone the Rock battery is Night and Day better than any other battery I have ever own.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
