Re: timing light
[Re: terzmo]
#3160213
07/17/23 10:41 AM
07/17/23 10:41 AM
Posts: 12,072 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Yes, same light for either. The real choice is whether you use an inductive vs an on-plug type light. Again, either will work but the inductive is usually more convenient if not a bit more finicky. Some lights struggle with multi strike ignitions.
I have had good luck looking on Marketplace or Craigslist for used ones. $20 or less usually. I have a couple of the old chrome Craftman inductives that have served me well. Bought both used. Only need one, but the last one was still in it's box, looking new for $10. Couldn't say no even though I didn't need it.
Master, again and still
Re: timing light
[Re: bobby66]
#3160226
07/17/23 11:44 AM
07/17/23 11:44 AM
Posts: 3,378 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Been using the old chrome Craftsman lights since the late 70's or so. So far, so good. Same. Non-dial back style--I just use a timing tape. Even used it with my old MSD 6AL box on my last car and it did not seem to mind..
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
Re: timing light
[Re: bobby66]
#3160311
07/17/23 03:34 PM
07/17/23 03:34 PM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Been using the old chrome Craftsman lights since the late 70's or so. S5o far, so good. Same here. But also bought a,Sun Engine Tune Up box set It is light, vacume, a line tgat screws into spark plug holes to test compression and that gauge so yiu can also compress to swap spring's or seals. And of coarse the Main bix that shows dwell, RPM ect. And a few other thing's ijjn there All like new
Re: timing light
[Re: terzmo]
#3160461
07/18/23 09:33 AM
07/18/23 09:33 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Yes. You do not want the vacuum advance to influence the initial setting. Just make sure that the carb does not have a resulting vacuum leak that could raise the idle.
Re: timing light
[Re: DaveRS23]
#3160462
07/18/23 09:37 AM
07/18/23 09:37 AM
Posts: 10,713 North Dakota
6PakBee
North Dakota
Typically what you are setting is base timing. There should be no vacuum advance due to vacuum (plug line) and no mechanical advance due to high engine speed (maintain specified idle speed). If you are setting total timing or something other than base, that is another conversation.
Re: timing light
[Re: 6PakBee]
#3160471
07/18/23 10:25 AM
07/18/23 10:25 AM
Posts: 4,672 Wichita
GY3
Wichita
Rev the engine until all the mechanical advance is in (vacuum advance disconnected). The rpm it is all in will be determined by the springs you have in the distributor. Put Mr. Gasket #925B in to get a quick advance.
Set the total timing there. Let the base timing fall where it will. I would start with 34-35*.
Re: timing light
[Re: DaveRS23]
#3160475
07/18/23 10:40 AM
07/18/23 10:40 AM
RapidRobert
Couldn't say no even though I didn't need it. that's the story of my life!
Re: timing light
[Re: moparx]
#3160630
07/18/23 04:08 PM
07/18/23 04:08 PM
GY3
Wichita
Set the total timing there. Let the base timing fall where it will. I would start with 34-35*. isn't the mr. gasket spring set for GM distributors ? #925B is two springs for the OEM Mopar distributors.
Re: timing light
[Re: moparx]
#3161052
07/19/23 03:33 PM
07/19/23 03:33 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
ok, thanks for the clarification. i thought, at one time anyway, there was a mr. gasket spring kit recommended that was for GM distributors. not that i can be "cornfused" easily............. They were available for GM type distributors the last time I checked. I bought 5 or 6 of the 95B kits to have them as needed, I do weld up the advance slots on the old type stock Mopar distributors and adjust the new type so I can have 12 to 16 degrees initial advance at a low idle and 34 to 36 degrees total advance above 2000 RPM
Re: timing light
[Re: Cab_Burge]
#3161610
07/21/23 12:34 PM
07/21/23 12:34 PM
Posts: 19,388 north of coder
moparx
i have welded the slots as well Cab, and i have a couple of those limiting plates here, but i have never tried those yet. a lot of performance can be gained by fiddling with the distributor weights and vacuum advance ! well worth the time trying different combinations, and a distributor machine will help, but not really necessary if one does not have access to one.
Re: timing light
[Re: moparx]
#3161843
07/22/23 09:16 AM
07/22/23 09:16 AM
Posts: 4,144 Canada -- Posts: 4034 -Registe...
5thAve
For some reason in the past few years I've had a couple timing lights come my way, still no digital ones or dial back ones tho and some are the older style that go in line with the plug wire. i have welded the slots as well Cab, and i have a couple of those limiting plates here, but i have never tried those yet. a lot of performance can be gained by fiddling with the distributor weights and vacuum advance ! well worth the time trying different combinations, and a distributor machine will help, but not really necessary if one does not have access to one. That's one nice thing about the mallory built mopar performance distributors, that you can you don't have to weld slots or change parts other then the springs.
