MSD Distributor Question again... #315947
05/12/09 02:45 PM
05/12/09 02:45 PM
MNobody Offline OP
MNobody  Offline OP
Well after reading the distributor phasing post i just had to check mine, with the reluctor lined up it look's like it is pointing right at #1 or real close but i noticed i have about 1/16" or a maybe a fuzz more slop in the shaft if you grab it and rotate it CW and CCW and it isn't the spring loaded pressure i'm referring to just free play that is probably where the slot in the drive gear comes into play. Is that normal or too much? Alsowith the rotor pointing to #1 and the reluctor lined up with the pickup my timing tape on the dampner is showing i'm 27 degrees advanced? My initial is set at 21 degrees so i'm a bit confused here, what's going on? Thanks.
Also with the timing mark at TDC the rotor is about a 1/2" CW past #1 on the cap and i noticed the burn mark on the rotor contact is right at the very edge on the right side in the pic. Something is fishy here, could the oil pump drive be a tooth off?
Re: MSD Distributor Question again... [Re: MNobody] #315948
05/12/09 03:04 PM
05/12/09 03:04 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
You are reading way too much into it.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: MSD Distributor Question again... [Re: HealthServices] #315949
05/12/09 03:22 PM
05/12/09 03:22 PM
MNobody Offline OP
MNobody  Offline OP
Huh? You mean it does'nt matter that the rotor does'nt point to #1 with the crank at TDC and the burn mark on the rotor is way off on the edge? I put a black mark on the right edge of the rotor contact, it's kinda hard to see...
Re: MSD Distributor Question again... [Re: MNobody] #315950
05/12/09 03:31 PM
05/12/09 03:31 PM
The burn mark on the edge does not bode well. Which side of the terminal? As timing advances the rotor will swing more CCW((BB) and CW(SB). Thats why it's best to drill the hole between center/#1 terminal & check it "at speed" with your light.
Re: MSD Distributor Question again... [Re: MNobody] #315951
05/12/09 03:35 PM
05/12/09 03:35 PM
So Cal
So Cal
It's good to have it phased yes, but don't read too much (meaning all the other stuff you are talking about) into it. It will not be phased exactly at the same spot at all rpms if you have vaccuum and mechanical advance.
Re: MSD Distributor Question again... [Re: RapidRobert] #315952
05/12/09 03:38 PM
05/12/09 03:38 PM
So Cal
So Cal
Like Robert says do it while the motor is running.
Re: MSD Distributor Question again... [Re: RapidRobert] #315953
05/12/09 03:38 PM
05/12/09 03:38 PM
MNobody Offline OP
MNobody  Offline OP
It's a SB motor and i can't tell on the terminal's in the cap the whole surface look's the same. Should the rotor be 1/2" past #1 in the cap with the crank at TDC?
Re: MSD Distributor Question again... [Re: MNobody] #315954
05/12/09 03:45 PM
05/12/09 03:45 PM
You had said that the edge was burned? You could remove the cap, drill it, replace it, grab your light & know exactly where you are at in 10 minutes.
Re: MSD Distributor Question again... [Re: RapidRobert] #315955
05/12/09 03:52 PM
05/12/09 03:52 PM
MNobody Offline OP
MNobody  Offline OP
The edge of the Rotor terminal is burned but the terminals in the cap don't show an obvios burn mark.
Re: MSD Distributor Question again... [Re: MNobody] #315956
05/12/09 03:55 PM
05/12/09 03:55 PM
So Cal
So Cal
Question is still the same what does it look like with it running? Put a hole in the distributor yet?
Re: MSD Distributor Question again... [Re: MNobody] #315957
05/12/09 03:55 PM
05/12/09 03:55 PM
My mistake. I read it wrong
Re: MSD Distributor Question again... [Re: HealthServices] #315958
05/12/09 04:11 PM
05/12/09 04:11 PM
MNobody Offline OP
MNobody  Offline OP
Can't afford to buy a new cap, so no i hav'nt drilled a hole. MSD cap's ain't cheap. I'm more concerned with the rotor location at TDC, If i move the drive gear a tooth, how much will it move the rotor? Thank's.
Re: MSD Distributor Question again... [Re: MNobody] #315959
05/12/09 04:17 PM
05/12/09 04:17 PM
If you choose to do so drilling the hole would not ruin the cap. Not sure on the amt by moving it one tooth but I would check that out
Re: MSD Distributor Question again... [Re: RapidRobert] #315960
05/12/09 04:20 PM
05/12/09 04:20 PM
So Cal
So Cal
I agree I had a hole in mine for a couple years before I finally replaced the cap.
look at the holes in this vented chevy cap.
You could always put a piece of tape over the hole if you drive your car in the rain.
Re: MSD Distributor Question again... [Re: MNobody] #315961
05/12/09 04:46 PM
05/12/09 04:46 PM
So Cal
So Cal
I do not have a distributor out so I cannot count the teeth but it would be the 360 divided by number of teeth. That will give you the amount in degrees of movement one tooth would do.
Re: MSD Distributor Question again... [Re: HealthServices] #315962
05/12/09 04:51 PM
05/12/09 04:51 PM
Excellent
Re: MSD Distributor Question again... [Re: HealthServices] #315963
05/12/09 05:22 PM
05/12/09 05:22 PM
MNobody Offline OP
MNobody  Offline OP
No kidding, well maybe i'll drill a 1/2" hole in it and check it out. I was afraid the spark might jump outta there and nail me LOL and i've been electrocuted enough lately. Thanks guy's.
