Re: chrysler mini starters
[Re: jwb123]
#3158758
07/11/23 09:26 AM
07/11/23 09:26 AM
Posts: 4,727 Moved to N.E. Tennessee
GomangoCuda
Junk yard starters are cheaper and generally better than the asian copies sold in the parts stores.
[Re: GomangoCuda]
#3158761
07/11/23 09:32 AM
07/11/23 09:32 AM
Posts: 4,986 new jersey usa
11secdart
new jersey usa
For some reason my Dart has been needing a starter every year , probably because the TTI headers are so close ,I got a Powermaster HiTorque starter from Summit , we will see how that holds up when my motor comes back from the shop
[Re: 11secdart]
#3158765
07/11/23 09:42 AM
07/11/23 09:42 AM
Posts: 4,684 Wichita
GY3
Wichita
I have an OE Nippendenso on my 505 and have for the last 7 years. Works perfectly.
[Re: jwb123]
#3158866
07/11/23 03:23 PM
07/11/23 03:23 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I’ve always used the factory nippondenso starters without issues. I added a trigger button on the contact solenoid for “wireless” starter bumping while adjusting clutch weights.
[Re: topside]
#3158960
07/11/23 08:23 PM
07/11/23 08:23 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
Never had an issue with any car I have raced using a Dakota mini starter, locked out dizzy, 13+ compression, etc, etc. Had my current car completely rewired about 4 years ago now. Since then it starts like it has a 16 volt battery. Guy who did the work( retired electrical engineer, who now does race car wiring on the side) told me having good wire and clean grounds is way more important than you would even think it is. I believe him! Check every connection, ground, wire size you can if one of those little starters has any issue turning a car over. Very unlikely it’s the issue, from my experiences
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: rebel]
#3160084
07/16/23 09:01 PM
07/16/23 09:01 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Not all starters for Mopars are the same. I have a 1.2kw a 1.6 kw & a 2 kw. The 2kw really spins the motor over, but has no snout to locate it. The 1.6 will spin your big block over fast enough but the 1.2 is more of a small blick v6 type. Not a long life item on a big block The 2kw doesn't need a snout to locate it. It's engineered to work that way. It's the only thing that will work with a powerglide. Theres not enough room in the powerglide bellhousing for the snout.
2011 Drag Pak Challenger
[Re: rickseeman]
#3160140
07/16/23 11:17 PM
07/16/23 11:17 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not all starters for Mopars are the same. I have a 1.2kw a 1.6 kw & a 2 kw. The 2kw really spins the motor over, but has no snout to locate it. The 1.6 will spin your big block over fast enough but the 1.2 is more of a small blick v6 type. Not a long life item on a big block The 2kw doesn't need a snout to locate it. It's engineered to work that way. It's the only thing that will work with a powerglide. Theres not enough room in the powerglide bellhousing for the snout. Be careful of your wording on that. It’s the only one maybe that will work without a simple mod. A cut off wheel handles that mod in minutes. Lol 😂
[Re: moparx]
#3160172
07/17/23 07:36 AM
07/17/23 07:36 AM
Posts: 9,847 MI, usa
dvw
MI, usa
what 16v regulator did you use Doug ? any changes to the factory wiring harness ? Depends on what alternator you have. Mines a Denso mini. Just oredered a regulator up on line. No wiring changes. Doug
[Re: pittsburghracer]
#3160185
07/17/23 09:15 AM
07/17/23 09:15 AM
rickseeman
Stuttgart, Arkansas
Not all starters for Mopars are the same. I have a 1.2kw a 1.6 kw & a 2 kw. The 2kw really spins the motor over, but has no snout to locate it. The 1.6 will spin your big block over fast enough but the 1.2 is more of a small blick v6 type. Not a long life item on a big block The 2kw doesn't need a snout to locate it. It's engineered to work that way. It's the only thing that will work with a powerglide. Theres not enough room in the powerglide bellhousing for the snout. Be careful of your wording on that. It’s the only one maybe that will work without a simple mod. A cut off wheel handles that mod in minutes. Lol 😂 Yes, but the others won't work at all.
