Viral 440 rebuild video #3158145
07/08/23 10:32 PM
07/08/23 10:32 PM
Nor here, Nor there
Dart 500 Online content OP
Dart 500  Online Content OP
Nor here, Nor there
...for some reason, a lot of non car people are sharing this and saying its great?
Re: Viral 440 rebuild video [Re: Dart 500] #3158157
07/08/23 11:41 PM
07/08/23 11:41 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
why is the center of that 440 that color?
Re: Viral 440 rebuild video [Re: A12] #3158159
07/09/23 12:00 AM
07/09/23 12:00 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
That used to be the "hot" trick, painting the valley red, aided oil drainback they said. eyes
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Viral 440 rebuild video [Re: A12] #3158173
07/09/23 03:29 AM
07/09/23 03:29 AM
To seal any residual gunk and debris from hot tanking and grinding the slag off of the lifter valley getting into the oil and supposedly aids oil return a little.
I can't remember the proper name of that sealer now but is has been used for a lot of years to do that up I'm going to say it is a Smokey Yunick and Grumpy Jekins trick originally, I don't have a clue who they pick that up from
I use Rust Oleum Damp Proof red primer to seal my motors, have for years and years with no issues up
Re: Viral 440 rebuild video [Re: Cab_Burge] #3158175
07/09/23 04:18 AM
07/09/23 04:18 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Thanks, now I know up This is my 440 block done by Koffel's Place II (just down the road from me), looks similar to that coating.
I guess I should have watched the first minute of the video as he mentions Glyptal (duh)
Glyptal Red Brush On
Seals uneven surfaces in engine
castings to improve oil circulation
Re: Viral 440 rebuild video [Re: A12] #3158176
07/09/23 05:26 AM
07/09/23 05:26 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Why does the cam gear look bent when he rotates it?
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Viral 440 rebuild video [Re: Savoy1964] #3158223
07/09/23 11:05 AM
07/09/23 11:05 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Say that also (at the 11:30-ish point) but then looked closely and I think the attachment bolt is missing and he was using the same cam gear to turn both the old and new cam as he was cleaning and just put it on slightly or just enough to turn them?
Re: Viral 440 rebuild video [Re: A12] #3158267
07/09/23 01:52 PM
07/09/23 01:52 PM
That is the rust Oleum primer up
