Re: Is there spmeone here that works on/repairs thermoquads
[Re: mopars4ever]
#3157623
07/06/23 05:20 PM
07/06/23 05:20 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
DEMONSIZZLER. But he hasn't posted here for almost 10 years.
Re: Is there someone here that works on/repairs thermoquads
[Re: Diplomat360]
#3157624
07/06/23 05:21 PM
07/06/23 05:21 PM
Posts: 13,584 md
mopars4ever
md
Diplo...Converting a lean burn thermoquad to work a non lean burn engine Gomango Do you know if he posting anywhere else? Thanks
[Re: a12rag]
#3157642
07/06/23 06:18 PM
07/06/23 06:18 PM
Posts: 13,584 md
mopars4ever
md
Do yourself a favor and get a non lean burn TQ. . . .no way to make a lean burn TQ work properly - so I have found.
Good luck . . .
Cheers
M What issues did you run into?
[Re: moparmike1]
#3157650
07/06/23 06:42 PM
07/06/23 06:42 PM
Posts: 5,948 British Columbia
chrisf
British Columbia
i have heard lots of good stuff about ken.
[Re: moparmike1]
#3157663
07/06/23 07:47 PM
07/06/23 07:47 PM
GomangoCuda
Pretty sure Harms only does OE restorations. Not modifications.
[Re: mopars4ever]
#3157826
07/07/23 03:26 PM
07/07/23 03:26 PM
Posts: 1,759 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Diplo...Converting a lean burn thermoquad to work a non lean burn engine... Well, there are a number of ways you can go about it, a lot of the approach depends on the starting point, that being the actual TQ model# you currently have. Yes, it is easier to get there if you start with a nonLB carb, but this is doable. Here, take a look at my complete CarterTQ library. I zipped up the whole structure of what I have in my private archive, it is about 250M in size so it'll take a while even on a fast internet connection. You will find a boat load of info there, including diagrams of the fuel circuits, Carter Tech Guide, etc. Point being, if you want to learn you certainly will have all the information you need, and as you progress through the modifications you can track your work in a thread here. On the other hand, if you are looking to send the carb over to someone to have it worked over, that may be a challenge today.
[Re: 340Cuda]
#3157863
07/07/23 05:59 PM
07/07/23 05:59 PM
Posts: 13,584 md
mopars4ever
md
There is a Thermoquad page on Facebook.
I know there is at least one rebuilder there that folks like a lot. Thanks for that
[Re: Diplomat360]
#3157865
07/07/23 06:04 PM
07/07/23 06:04 PM
Posts: 13,584 md
mopars4ever
md
Diplo...Converting a lean burn thermoquad to work a non lean burn engine... Well, there are a number of ways you can go about it, a lot of the approach depends on the starting point, that being the actual TQ model# you currently have. Yes, it is easier to get there if you start with a nonLB carb, but this is doable. Here, take a look at my complete CarterTQ library. I zipped up the whole structure of what I have in my private archive, it is about 250M in size so it'll take a while even on a fast internet connection. You will find a boat load of info there, including diagrams of the fuel circuits, Carter Tech Guide, etc. Point being, if you want to learn you certainly will have all the information you need, and as you progress through the modifications you can track your work in a thread here. On the other hand, if you are looking to send the carb over to someone to have it worked over, that may be a challenge today. At first I was thinking on doing it myself but more so now looking for it to be done by someone with knowledge which I have none.
[Re: Moparite]
#3158030
07/08/23 02:20 PM
07/08/23 02:20 PM
Posts: 19,396 north of coder
moparx
it took me several years and many failed attempts to finally figure out the T-quad, but now i really like them. i pick up all the ones i can at swaps for parts or just good carbs cheap, because others don't like them, or can't figure them out. these things are not for the super high horse power engine, but work very well as a street/strip carb when set up properly. just my old geezer life experience, failures included. your mileage will vary.
[Re: moparx]
#3158055
07/08/23 03:19 PM
07/08/23 03:19 PM
Posts: 16,816 Between Houston & Galveston TX
SattyNoCar
Big fan of TQ's myself, used them for 30+ years. As for the Lean Burn versions, I've made the earlier ones work with little effort. The biggest issue was no ported vacuum for the vacuum advance, which I was able to add. It's the later ones that have more electronics built in that you'll have difficulties. The TQ on my wagon had gone to crap from sitting, and the buyer made the comment 'typical TQ' when it wouldn't run right because of it. I so wish I had taken the time to sort it before selling. All the TQ's I ran were on stock engines, so can't tell ya' about putting one on something cammed and making real power, but for my intentions, they were great. Ever have an old man flip you off because your car started so quick? I have.
John
[Re: SattyNoCar]
#3158132
07/08/23 09:28 PM
07/08/23 09:28 PM
Posts: 15,355 Omaha Ne
TJP
Omaha Ne
Big fan of TQ's myself, used them for 30+ years. As for the Lean Burn versions, I've made the earlier ones work with little effort. The biggest issue was no ported vacuum for the vacuum advance, which I was able to add. It's the later ones that have more electronics built in that you'll have difficulties. The TQ on my wagon had gone to crap from sitting, and the buyer made the comment 'typical TQ' when it wouldn't run right because of it. I so wish I had taken the time to sort it before selling. All the TQ's I ran were on stock engines, so can't tell ya' about putting one on something cammed and making real power, but for my intentions, they were great. Ever have an old man flip you off because your car started so quick? I have. 69 Dart 4 spd, mid to low 12's I'll admit it was a 71 version
