Magnesium Hemi crossrams #3157057
07/04/23 10:24 PM
07/04/23 10:24 PM
Stuttgart, Arkansas
rickseeman Offline OP
Stuttgart, Arkansas
I know this is a tough question but, the mag hemi crossrams don't have a date code on them like the aluminum ones do. Is there a way to tell which ones would be proper on a 65 and which ones would have been made for a 68? Of course they sold these over-the-counter for a long time also. The photos are of 2 different intakes. The castings tags are slightly different. There are also 2 tags each on the side and I sent a photo of the best one. I know it's a tough question but I thought i'd ask. Thanks.
CED7E0D5-FC12-4B1D-A0F4-AE84C92FC910_1_105_c.jpeg0A2A4350-230D-4FCC-86EF-725D4295E34D_1_105_c.jpegB599FB3E-56C7-40E0-8D90-59233D624108_1_105_c.jpeg
2011 Drag Pak Challenger
Re: Magnesium Hemi crossrams [Re: rickseeman] #3157112
07/05/23 07:25 AM
07/05/23 07:25 AM
VA
dragon slayer Offline
VA
No expert here, but the first street hemi manifolds had WBAC casting. 66-67 model year. They also had MLT tag, but I don't know how you make any sense out of it. I have 3 manifolds (street hemi) with MLT P10NA; 6P063P; 18CA.
Interested to hear some answers.
Re: Magnesium Hemi crossrams [Re: rickseeman] #3157131
07/05/23 10:03 AM
07/05/23 10:03 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Maybe get a hold of one of the guys that restores those cars.
Start with Kramer
Kramer Automotive Specialties
P.O. Box 5
Herman, PA 16039
PH: 724.285.5566
FX: 724.285.8898
Email: info@kramerauto.com
Re: Magnesium Hemi crossrams [Re: GomangoCuda] #3157141
07/05/23 10:40 AM
07/05/23 10:40 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Mine had no numbers on it, been "massaged" by Diamond-Elkins...
JB Rhinehart, Realist
A-Body's RULE!
Re: Magnesium Hemi crossrams [Re: Rhinodart] #3157903
07/07/23 10:20 PM
07/07/23 10:20 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
What difference does it really make if the magnesium manifold was cast in 1965 or 1968?
Magnesium can't talk.
There is no way to tell.
I owned this magnesium intake manifold and carbs, for years before i sold it off.
You are correct, no casting dates on it.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Magnesium Hemi crossrams [Re: hemi71x] #3158010
07/08/23 12:19 PM
07/08/23 12:19 PM
A727Tflite Offline
A727Tflite  Offline
Just a SWAG, the cast info is more likely the core info, and core level along with the foundry ID and of course the part number.
The numbers stamped in the pad are likely the machined date.
Something as small as a production run like this manifold probably used batches of cast manifolds stored, then when machined had the date of machining as the control.
You will have to look at a few manifolds to see if there is a pattern in the stamping numbers.
Re: Magnesium Hemi crossrams [Re: A727Tflite] #3158321
07/09/23 05:43 PM
07/09/23 05:43 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
It doesn't really matter to me. I just thought if anyone was still alive with that info now would be the time to get it.
