Re: T/a challenger turn signal switch
[Re: greendart408]
#3157007
07/04/23 07:19 PM
07/04/23 07:19 PM
Posts: 145 Canada
EW1BH27
Canada
What does “no good” mean? Does the right side not blink, or the left side or both? Is the flasher knob broken off? Does it not reset after making a turn? You realize that 1970 E-body is a unique one year only turn signal switch. Good luck finding an NOS one or even a used one.
If it doesn’t reset, the internal cam is reproduced(if that’s the issue). Sometimes just cleaning and bending the contacts gets them working (if that’s the issue)
EDIT: I've also seen the insulation cut on some of the wires on its harness, possibly shorting and wires completely cut.too.
[Re: EW1BH27]
#3157028
07/04/23 08:57 PM
07/04/23 08:57 PM
Posts: 4,743 Florida
BDW
[Re: EW1BH27]
#3157292
07/05/23 05:44 PM
07/05/23 05:44 PM
Posts: 1,073 oregon
greendart408
oregon
EDIT: I've also seen the insulation cut on some of the wires on its harness, possibly shorting and wires completely cut.too. My dad, her brother has already looked into what was up with it. Neither of them are on moparts, I was asked to make a post about it. All I was told is that my dad hooked up a dart switch temporarily and the brake lights work again. I will check into and get back. It’s an unrestored mint car. We don’t want re pop junk if we can help it.
[Re: Alaskan_TA]
#3157967
07/08/23 08:22 AM
07/08/23 08:22 AM
Posts: 145 Canada
EW1BH27
Canada
Does your dad have the bullet terminal release tool? (The plastic terminal end will not pass through the column so the wire ends need to be removed from the plastic connector)
I've never had a problem fishing the connector through the column. Just needed to take off the metal cover near the bottom of the column.
[Re: greendart408]
#3158102
07/08/23 07:09 PM
07/08/23 07:09 PM
Posts: 404 IL us
ink
IL us
i just went through this with my Cuda ,, after I bought a new switch and two days of lqqking for a short I replaced both flashers. (There are two) id tried swapping the flashers with one another days earlier and it didn't make a difference, so I had figured they were both good??? (not) so if it hasn't been asked yet? have you checked BOTH flasher? a bad flasher will cause a lot of different problems! and I had a few going on ,
[Re: Alaskan_TA]
#3158649
07/10/23 09:14 PM
07/10/23 09:14 PM
Posts: 1,073 oregon
greendart408
oregon
Hooking up a known, good switch is the best way to diagnose this issue.
With a brake light issue, it can be either the wire itself or the hazard part of the turn signal switch may have failed internally.
I ran into the same situation with a pal's Superbird, in that case, the brake circuit wire passed a continuity test & the issue was inside the switch.
Barry, I will get with my dad and look into thanks
[Re: ink]
#3158650
07/10/23 09:15 PM
07/10/23 09:15 PM
Posts: 1,073 oregon
greendart408
oregon
i just went through this with my Cuda ,, after I bought a new switch and two days of lqqking for a short I replaced both flashers. (There are two) id tried swapping the flashers with one another days earlier and it didn't make a difference, so I had figured they were both good??? (not) so if it hasn't been asked yet? have you checked BOTH flasher? a bad flasher will cause a lot of different problems! and I had a few going on , Her car did have a weird flasher issue the past few yrs also. Will check into this more thanks
