Re: Never goes racing….. still buying bitchin parts
[Re: J_BODY]
#3156568
07/03/23 02:11 PM
07/03/23 02:11 PM
Posts: 19,520 north of coder
moparx
seeing that the transmission pan uses nuts, with studs in the case, to secure it, a question i have always wondered about. has anyone had the studs back out of the case when removing the pan nuts ? are the studs loctited at installation ? if so, what color of loctite was used ? TIA to those smarter than me, that can answer this old man's stupid question.
[Re: moparx]
#3156610
07/03/23 04:21 PM
07/03/23 04:21 PM
Posts: 1,841 South Bend
John Brown
South Bend
I used the studs and nuts combo with flat washers under the nuts on a brand new STR Edelbrock crossram. I put the studs in using red Loctite cause I knew I was never gonna remove them. They never backed out a bit.
[Re: moparx]
#3156611
07/03/23 04:39 PM
07/03/23 04:39 PM
Posts: 1,763 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
seeing that the transmission pan uses nuts, with studs in the case, to secure it, a question i have always wondered about... I like the stud idea here, would make the job of installing a new gasket that much easier (it being an upside-down job). I'm curious, what part# is that setup/kit? Re: colour, I used the ORANGE colour to setup my valve cover studs. It is strong enough to keep things planted, but not as robust as the RED stuff.
[Re: J_BODY]
#3156672
07/03/23 07:59 PM
07/03/23 07:59 PM
Posts: 10,039 MN
JERICOGTX
MN
Ah the chase for 8.99. Nice piece for sure. Doug I’m still po’ed you got there before me and now Jeff is knocking on the door! I’m not chasing a piece of paper…
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3156713
07/03/23 09:39 PM
07/03/23 09:39 PM
Posts: 13,201 aZLiViN
J_BODY
aZLiViN
Ah the chase for 8.99. Nice piece for sure. Doug I’m still po’ed you got there before me and now Jeff is knocking on the door! I’m not chasing a piece of paper… WHAT EVER!! you’ll be proud like Clark Griswold jumping 50 yards!
[Re: Diplomat360]
#3156717
07/03/23 09:42 PM
07/03/23 09:42 PM
J_BODY
aZLiViN
[Re: Diplomat360]
#3156870
07/04/23 01:34 PM
07/04/23 01:34 PM
moparx
seeing that the transmission pan uses nuts, with studs in the case, to secure it, a question i have always wondered about... I like the stud idea here, would make the job of installing a new gasket that much easier (it being an upside-down job). I'm curious, what part# is that setup/kit? Re: colour, I used the ORANGE colour to setup my valve cover studs. It is strong enough to keep things planted, but not as robust as the RED stuff. thank you sir !
