LITE WEIGHT CARPET #3155789
07/01/23 02:32 AM
07/01/23 02:32 AM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
NHRA class car what is a good source of lite weight carpet?
Thanks in advance, Rod
Real Men shift for themselves
Re: LITE WEIGHT CARPET [Re: 1DGEMAN] #3155792
07/01/23 04:55 AM
07/01/23 04:55 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Have you looked at boat carpet? It's pretty lite, need to glue it to make it stay put.
Re: LITE WEIGHT CARPET [Re: rebel] #3155825
07/01/23 08:34 AM
07/01/23 08:34 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've been able to specify "no jute or backing" for auto carpet in the past; not sure if you still can.
Seemed about half the weight without it.
For flat areas, the rolls of carpet from the auto parts store are thin & light.
Re: LITE WEIGHT CARPET [Re: topside] #3155876
07/01/23 11:18 AM
07/01/23 11:18 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: LITE WEIGHT CARPET [Re: 1DGEMAN] #3155915
07/01/23 12:49 PM
07/01/23 12:49 PM
Aircraft carpet scope up
Re: LITE WEIGHT CARPET [Re: Cab_Burge] #3155956
07/01/23 02:37 PM
07/01/23 02:37 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
[b][/b]
Regular carpet set only weighs 25 pounds, so weight savings isn’t gonna amount to much getting something lighter that will probably look cheezy
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: LITE WEIGHT CARPET [Re: B3422W5] #3156019
07/01/23 06:31 PM
07/01/23 06:31 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by B3422W5
[b][/b]
Aircraft carpet is the right answer.
25 pounds in a Stocker is a bunch. I've spent considerable time trimming that much out of a car.
Re: LITE WEIGHT CARPET [Re: CMcAllister] #3156072
07/01/23 10:29 PM
07/01/23 10:29 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
[b][/b]
Those cars typically have to weigh 3300 + pounds(Abody small blocks). They sometimes carry extra weight to get there.
Sure, stock carpet is 25 pounds, but whatever you replace it with doesn’t weigh zero, it weighs something. I wouldn’t think carpet is bad weight compared to other things.
1.41 best 60 foot
6.56 at 104.17
Re: LITE WEIGHT CARPET [Re: B3422W5] #3156140
07/02/23 09:35 AM
07/02/23 09:35 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
home depot. not to many colors, .60 square ft.
took out power seats, a/c heater unit, wipers, carpets. spare tire etc. had to add 600 lbs. to make weight
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: LITE WEIGHT CARPET [Re: 440lebaron] #3156217
07/02/23 01:13 PM
07/02/23 01:13 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I have a entire roll of thin carpet used the rear area of suvs, vans etc. It's 61.5" wide. About .070" thick. I could cut you a chunk if you want to pay the shipping.
Doug
Re: LITE WEIGHT CARPET [Re: dvw] #3156250
07/02/23 03:07 PM
07/02/23 03:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Actually, for areas you're not basically walking on, you could use felt.
Downside is felt works like velcro for hair, tiny pebbles, leaves, etc.
Re: LITE WEIGHT CARPET [Re: topside] #3156685
07/03/23 08:38 PM
07/03/23 08:38 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Home Depot indoor/outdoor I believe it was 6x8 roll. My wife made patterns with brown masking paper. Then transposed it to the carpet. Cut out pieces. Trim around roll bar. Affix with carper tape and Velcro as needed. Lite weigh and looks great.
67175573167__29E6495F-72F0-4325-9DFD-55AD9345B5FB.jpeg67175569957__BC480BA1-3AB1-4474-B162-0BC2AA762A48.jpeg67172840628__EFF61D1D-B960-405D-9F67-7F21D2F3A542.jpeg
Re: LITE WEIGHT CARPET [Re: actionange] #3156815
07/04/23 09:40 AM
07/04/23 09:40 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
That looks VERY nice! Great Job!
I ended up using the carpet they put on speaker boxes. Very thin, very lightweight, BUT, very easy to damage. My heel wears a hole in it at least once a season. I like your idea and will go with this stuff next time.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
