Re: Like Roller Coasters? Watch THIS
[Re: Moparite]
#3156637
07/03/23 05:50 PM
07/03/23 05:50 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
Makes you wander what else they didn't see. Shut the ride down and loose X amount of $$$. Hard to believe but it still happens. It probably depends on which staethe roller coasters are in on how often they need a state inspection and recertification. I was told that all the roller coasters in CA theme parks like Magic Mountain and Disney Land need a visual inspection every day before it operates by a state certified company employee before being allowed to run the day
[Re: Cab_Burge]
#3156675
07/03/23 08:05 PM
07/03/23 08:05 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Imo there is an easy confidence building final straw last resort wireless fix here that maybe should be mandated on these structures. Motion sensors would have detected that extra movement observed or remote optical laser sensors with specific realtime 24/7 targets on the structure would also detect out of range movement of the support structure. Both solutions could be computer monitored with out of limit warnings and override shutdowns capability. Both would be most important on the first no passenger test run of the day, and every run thereafter.
[Re: TJP]
#3156817
07/04/23 09:44 AM
07/04/23 09:44 AM
Posts: 4,770 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Food, car parts, repair contractors -all of it is not available, expensive or non existent due to people not working or the people working not giving a damn. Why would amusement park maintenance crews be any different.
Keep old mopars alive.
