Staggered wheel setup- understeer? #3155493
06/30/23 08:56 AM
06/30/23 08:56 AM
Knoxville, TN
Y
YGBSM Offline OP
YGBSM  Offline OP
Y
Knoxville, TN
Right now I have 15x7 all around.
I'm getting some new wheels, thinking about 15x7 up front and 15x8 in the back. Will this cause understeer?
1968 Charger R/T
2015 Charger R/T Scat Pack
2017 Durango Citadel
Re: Staggered wheel setup- understeer? [Re: YGBSM] #3155623
06/30/23 04:25 PM
06/30/23 04:25 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
That is an oversimplified question. It is impossible to properly answer based on several bits of missing information.
Look at what leads to understeer and oversteer as one guide, Also take consideration that the automakers built the cars with a strong bias toward safety and control. UNDERsteer is naturally self healing. One understeers, then slows down until control comes back to them.
One rule that seems to hold true: The end of the car with the greatest roll stiffness will lose traction first.
Stiff leaf springs and a fat rear sway bar on a car with stock torsion bars and no sway bar would very likely result in oversteer when subjected to quick maneuvers.
All high performance sports cars have different wheel and tire sizes front/rear. Of course, any disparity between the grip is offset by chassis engineering.
I run a 295 rear tire and a 275 front. Mine is neutral until I stab the throttle to kick the ass end out.
Re: Staggered wheel setup- understeer? [Re: Kern Dog] #3155650
06/30/23 06:55 PM
06/30/23 06:55 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Missing a heck of a lot more than several bits of information.
Re: Staggered wheel setup- understeer? [Re: YGBSM] #3155795
07/01/23 05:26 AM
07/01/23 05:26 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
"I'm getting some new wheels, thinking about 15x7 up front and 15x8 in the back. Will this cause understeer?"
With only that little of info, the most accurate simplistic answer would likely be, it will change the balance, whatever that currently is, and it will be TOWARDS understeer, which maybe is your objective?
Re: Staggered wheel setup- understeer? [Re: YGBSM] #3158383
07/09/23 11:30 PM
07/09/23 11:30 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
so no tire size change? a 1" wider rim at the rear will not do much at all. an air pressure adjustment would be a bigger ....
Re: Staggered wheel setup- understeer? [Re: ek3] #3158858
07/11/23 02:47 PM
07/11/23 02:47 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
This book, one of the best car books I have ever read of dozens, has one line of many, that hits the nail on the head best regarding car modifications:
" Everything effects everything else"
Think-fast-the-racers-why-to-guide-to-winning_by Neil Roberts
