Re: E Body window crank spacers
[Re: BDW]
#3155746
06/30/23 10:10 PM
06/30/23 10:10 PM
Posts: 307 Georgia
69bfan
Georgia
When purchasing the window crank with spacers for the rear quarter glass windows, you must select the body style. The 70-74 Cuda quarter glass window cranks use a 1/2 inch thick spacer, the 70-74 Challenger rear quarter glass window crank spacers are 1/4 inch thick and the 67-70 B-bodies use the same spacer for both the front and rear glass and it is approximately 1/8 inch thick. The 62 to 66 A&B-bodies use a really thin spacer. The front door glass window crank spacers for the E-Body applications is the same as the 67 and up A, B and C-Body applications. The correct spacers can be purchased by themselves if you need just that piece.
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
[Re: BDW]
#3160494
07/18/23 11:12 AM
07/18/23 11:12 AM
MoreParts
Thx for the info, good to know there are 3 different spacers. Looks like the middle 1 is harder to find. All the aftermarket seem to be thin or thick. NP. Those spacers you have pictured above my parts# post are the middle sized ones.
