Re: comp 829-1 roller lifter assembly
[Re: ToddP]
#315570
05/11/09 11:27 PM
05/11/09 11:27 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I notice during a cleaning slight air pressure will pop those right out. So they should be good to go, after a clean bill of health for the rollers is determined.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: HPMike]
#315575
05/12/09 10:44 AM
05/12/09 10:44 AM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
Todd;
Might be an optical illusion from the pic, but it looks like your pushrods may be too short(adjuster sunk into the locknut)??
MB
That's what I was thinking. Should be 2 threads max inlieu of the 5 I see.
[Re: cudarex]
#315576
05/12/09 12:03 PM
05/12/09 12:03 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Looks to me like the rocker broke accross the hole, there's not that much sticking out the actual original bottom. Question is why did that one break? What are the springs like? What cam? ANy cahnce the valve is bouncing on the seat? Did the roller pop out of it's bore?
[Re: ToddP]
#315578
05/12/09 10:13 PM
05/12/09 10:13 PM
BradH
... 8000 street driven miles on used rockers... 200lbs on the seat 650lbs open spring pressure...
I don't think you have to look too hard to see why your rockers are ready for replacement.
[Re: Thumperdart]
#315581
05/13/09 07:17 AM
05/13/09 07:17 AM
moper
Columbia, CT
Like Brad.. I'd say time for new rockers. I don't think I'd go Harlands for 650 lbs open stuff. With that much, the valve ain't bouncing... that's for sure. But I think it's time.
[Re: 52savoy]
#315583
05/14/09 07:17 AM
05/14/09 07:17 AM
Posts: 684 Milwaukee
ToddP
super street
super street
Milwaukee
Dwayne did not spec out the springs. These were again used springs that came with the used heads. Dwayne did a valve job and flowed a few ports. Cam specs.int 4149 lobe 260* ex 4020 lobe 266* lobe sep 114* I double checked comps web site for 999 spring info. 196 lbs. closed and 608lbs@.650" lift. I am sure the pressure is lower, with as many of miles. I did check all the rockers for signs of stress cracks. Looks ok? I feel lucky for as little damage that appears. New rocker will be here friday.
