2009 challenger timing chain recall? #3155074
06/28/23 09:27 PM
06/28/23 09:27 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
So I got a friend with an 09 challenger R/T and the timing chain is broken, I can see the chain is not on the gear thru the cam sensor hole and it spins over real fast like a bunch of bent valves. As best I can tell from mopar.com is the chains were replaced but yet here we are. It only has 101,000 miles or so, is there any chance Dodge will do anything about this or is he AOL?
Any service writers or anything can give any advice?
Re: 2009 challenger timing chain recall? [Re: HotRodDave] #3155086
06/28/23 10:19 PM
06/28/23 10:19 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
Are you able to run a carfax and get the dealer name that did the work and when? I'd start there.
Re: 2009 challenger timing chain recall? [Re: Dart 500] #3155121
06/29/23 02:19 AM
06/29/23 02:19 AM
Park Forest, IL
slantzilla Offline
Happy Birthday slantzilla  Offline
Park Forest, IL
Is it an auto or stick? IIRC, the recall was auto only. My 6 speed SRT-8 was not covered.
Re: 2009 challenger timing chain recall? [Re: slantzilla] #3155142
06/29/23 07:18 AM
06/29/23 07:18 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
If he is the original owner, 2009 Challengers had a lifetime power train warranty.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: 2009 challenger timing chain recall? [Re: chargervert] #3155143
06/29/23 07:24 AM
06/29/23 07:24 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
IF he had the 5 year inspections performed. Many reports of troubles even if the inspections were performed.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 2009 challenger timing chain recall? [Re: 3hundred] #3155147
06/29/23 07:44 AM
06/29/23 07:44 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
I had a '12 rt that threw a few codes that correlated to timing chain replacement. My car was at 26k miles when it did this, and I was surprised to see it was an incredibly common occurrence. Theres even an article on Hotrod.com about it. Anyways, you have to go to chryslers recall web site and type in the vin number in the designated area. I thought all RTs were covered, they're not. Its a huge load of bull$hite. Best of luck.
Re: 2009 challenger timing chain recall? [Re: moparjim79] #3155219
06/29/23 12:22 PM
06/29/23 12:22 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
My 2009 Challenger R/T had the timing chain tensioner replaced back in like 2011 or so. And now the car has 263,000 issue free miles on it. It's an auto as well.
Re: 2009 challenger timing chain recall? [Re: Devil] #3155518
06/30/23 11:16 AM
06/30/23 11:16 AM
chargervert Offline
chargervert  Offline
My wife's 2009 had the timing chain recall, no issues before or after having it done. Her car only has 36k miles on it. My 2010 is a six speed so it doesn't have the timing chain issue.
Re: 2009 challenger timing chain recall? [Re: chargervert] #3155642
06/30/23 06:19 PM
06/30/23 06:19 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
