Page 1 of 3 1 2 3
Switch to synthetic oil #3155024
06/28/23 07:27 PM
06/28/23 07:27 PM
Just South of The Motor City
limechallenger Offline OP
I've got a 70 Challenger T/A with a slightly built 340-6 ,I've always used conventional oil,but wondering if a switch to synthetic will have any negative affects? Thought I'd ask before doing it!
70 T/A Challenger 78 Aspen R/T 87 Indy 500 Dakota
Re: Switch to synthetic oil [Re: limechallenger] #3155035
06/28/23 07:58 PM
06/28/23 07:58 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Anyone telling you there would be negative effects, other than on your bank account, is someone to pass by when advice is being handed out.
Re: Switch to synthetic oil [Re: Sniper] #3155040
06/28/23 08:08 PM
06/28/23 08:08 PM
So it's a worthwhile switch for older motors?
Re: Switch to synthetic oil [Re: limechallenger] #3155042
06/28/23 08:21 PM
06/28/23 08:21 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Unless you are leaking oil already it is a worthwhile switch.
Re: Switch to synthetic oil [Re: Sniper] #3155052
06/28/23 08:33 PM
06/28/23 08:33 PM
Ok thanks!
Re: Switch to synthetic oil [Re: limechallenger] #3155111
06/29/23 01:00 AM
06/29/23 01:00 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Synthetic will clean better and gunked up or coked deposits can be cleaned away over time and you’ll have a new leak. That’s the only downside other than price.
I want my fair share
Re: Switch to synthetic oil [Re: limechallenger] #3155117
06/29/23 01:31 AM
06/29/23 01:31 AM
Synthetic oils shruggy scope will leak out of a engine that has no leaks with petroleum based oils
I wouldn't switch any old muscle car motor to synthetic oils due to the fact they were designed to run on petroleum oils down work twocents
Re: Switch to synthetic oil [Re: Cab_Burge] #3155125
06/29/23 05:03 AM
06/29/23 05:03 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Try it and tell us how well that worked out for you.
Re: Switch to synthetic oil [Re: Cab_Burge] #3155154
06/29/23 08:33 AM
06/29/23 08:33 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Modern synthetics do not cause leaks. Early formulations did, to some extent.
Re: Switch to synthetic oil [Re: Sniper] #3155226
06/29/23 12:43 PM
06/29/23 12:43 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
If it's a flat tappet cam I would be more concerned with zinc content. Some of the high zinc oils like Brad Penn are semi-synthetic.
Re: Switch to synthetic oil [Re: Dcuda69] #3155230
06/29/23 12:52 PM
06/29/23 12:52 PM
I was told years ago that all multi weight oils, 5W20Wt,10W30WT and so on, all were based on semi synthetic technology shruggy
Re: Switch to synthetic oil [Re: Cab_Burge] #3155298
06/29/23 03:39 PM
06/29/23 03:39 PM
moparx Offline
moparx  Offline
any more, all one can do is read the "fine print" on the bottle, unless the label states the oil is for flat tappet cams, such as the Joe Gibbs stuff.
beer
Re: Switch to synthetic oil [Re: moparx] #3155406
06/29/23 08:49 PM
06/29/23 08:49 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Use Brad Penn or Driven semi with zinc.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Switch to synthetic oil [Re: Cab_Burge] #3155489
06/30/23 08:45 AM
06/30/23 08:45 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
The MSDS will tell you what it is made of. Just because someone said something doesn't means they know anything.
Re: Switch to synthetic oil [Re: Sniper] #3155556
06/30/23 01:02 PM
06/30/23 01:02 PM
moparx Offline
moparx  Offline
keep in mind, the super thin [wt wise] oils are for modern engine clearances, which are much tighter.
beer
Re: Switch to synthetic oil [Re: moparx] #3155557
06/30/23 01:11 PM
06/30/23 01:11 PM
340SIX Offline
340SIX  Offline
beer
This.
On the Engine Masters the 20/50 even made more power, over the thin stuff
But in that case it showed it was the right oil for that motor.
Re: Switch to synthetic oil [Re: 340SIX] #3155589
06/30/23 02:13 PM
06/30/23 02:13 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yeah, their conclusion was that the thicker 20W-50 aided ring seal in that engine.
I was a bit surprised that it picked up power vs the thinner oil, but there it was...
Whether there was an issue with that engine's ring seal wasn't analyzed.
Re: Switch to synthetic oil [Re: 340SIX] #3155617
06/30/23 04:04 PM
06/30/23 04:04 PM
Only guys like them could FUBAR a oil viscosity test like they did haha
I learned a long time ago to make sure any new engine being dyno tested on an engine dyno or a chassis dyno are broken in properly to insure the ring seal is completed and the rings are seated properly work up Zero to no more than 10 % leak down done with the motor warm or hot wrenchup
I wonder if they had that block honed with a torque plate and the proper head gasket under it so it would hone properly work shruggy
Re: Switch to synthetic oil [Re: Dcuda69] #3155656
06/30/23 07:21 PM
06/30/23 07:21 PM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
I agree, I would be concerned about the zinc content as well with a flat tappet cam.
Re: Switch to synthetic oil [Re: topside] #3155804
07/01/23 07:12 AM
07/01/23 07:12 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Me too, I just wondered if that engine which was quoted to have "a ton of laps on" (Dyno), would be equally as worn when compared to a used street / strip or a drag race engine that's made 100+ passes shruggy
Page 1 of 3 1 2 3
