Re: Sweptline Camper , California
[Re: bigdad]
#3154322
06/26/23 10:56 AM
06/26/23 10:56 AM
Posts: 16,816 Between Houston & Galveston TX
SattyNoCar
If the story is true, the price doesn't seem bad, no? This dodge was built by a heavy duty truck mechanic and almost everything on it is overbuilt. The builder use to lead over-landing tours with it from California to Alaska. It sits on a one ton dually chassis. It's powered by a commercial p-pump turbocharged 12v cummins, military M35A2 transmission and 1-ton axles. Behind the cab is a full service utility bed and a custom tig welded aluminum framed camper. It can cruise at 70mph and drives nice and straight. Below are some of the features..... manual transmission -NP201 transfer case -Dana 80 front/rear axles -Custom heavy duty steering -Heavy duty suspension/mounts -Power Hydroboost brakes -Power steering - commercial steering pump turns the truck with one finger even when parked -Dual radiators w/ electric fans -PTO powered winch -Pull out awning -Aluminum ladder w steps for roof access -On-board air compressor w/ plumbing -Brand new (6) Firestone commercial tires -Custom rear bumper -Towing hitch with custom step -Factory fuel tank w/ additional 100 gallon reserve diesel tank and transfer pump -Clean water tank -Grey water tank -Ceiling vent -Bathroom w/ sink -Kitchenette w/ sink, stove, vented hood, fridge -Custom cabinetry with tons of storage -Full exterior locking steel storage provides even more storage. -Radio, speakers, charging ports and 110v hookup w/ outlets in camper -Stainless counter tops -New carpet & upholstery on interior -New window seals/felts -Aftermarket oil pressure, volt, water, air, EGT and boost gauges
John
