speedometer gear #315406
05/11/09 08:48 PM
05/11/09 08:48 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
I have 3:55 gears with 275-60-r15 rear tires what trans gear do i need for a 904? Is a 727 the same?
Re: speedometer gear [Re: bobs69] #315407
05/11/09 09:08 PM
05/11/09 09:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Info you need is here from the tech archives. http://www.moparts.org/Tech/Archive/auto/12.html
Re: speedometer gear [Re: bobs69] #315408
05/12/09 01:32 AM
05/12/09 01:32 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
33 ( yellow )
yes is the same
Re: speedometer gear [Re: NachoRT74] #315409
05/12/09 09:35 AM
05/12/09 09:35 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Make sure that the housing that holds the gear is indexed properly
Re: speedometer gear [Re: GTXKen] #315410
05/25/09 03:42 PM
05/25/09 03:42 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
How do i index it?
Re: speedometer gear [Re: bobs69] #315411
05/25/09 04:10 PM
05/25/09 04:10 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
How do i index it?
You rotate the pinion adapter until the tooth range you're using is at the 6 o'clock position, as shown in the attached image.
Mods, can this image/info be added to the speedo pinion gear info in the tech archives, please?
OK, I found the info in the archives, but there's no mention of how to properly position the adapter, so maybe just an edit would help: http://www.moparts.org/Tech/Archive/auto/21.html
Re: speedometer gear [Re: In_The_Pink] #315412
06/14/10 09:00 AM
06/14/10 09:00 AM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
