Crappy design on a Mopar #3153726
06/23/23 06:45 AM
06/23/23 06:45 AM
Iceland
BadMoonRacer Offline OP
Iceland
I would like to hear the argument for the aluminium lined wheel lugs on late Chargers with factory hubcaps. What a crappy design!
These are mine, after I wrestled them off. Converting to another set of wheels to avoid this mess.
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials.
Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: Crappy design on a Mopar [Re: BadMoonRacer] #3153739
06/23/23 07:39 AM
06/23/23 07:39 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
They were on most vehicles starting in the late seventies, not just on Mopars. Whoever designed them should have been fired,but probably got a promotion for saving money!
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Crappy design on a Mopar [Re: BadMoonRacer] #3153741
06/23/23 07:41 AM
06/23/23 07:41 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
They're just cheap junk. I first saw them on 1972 GM cars with the optional wheels. Sometime before 1978, we ran across one on a Pontiac with Rally II wheels we couldn't get off. We wound up using an air chisel to get it off. Despite trying to be careful the wheel was badly damaged from an appearance standpoint. Our '13 and '16 300 and Durango all came with that garbage. I replaced all with all steel chrome nuts indistinguishable from the original aside from being slightly longer.
If not these, then pretty danged close. If you live in the rust belt, be proactive and replace the factory garbage before they become a problem.
https://www.ebay.com/itm/134379235433?
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Crappy design on a Mopar [Re: BadMoonRacer] #3153742
06/23/23 07:41 AM
06/23/23 07:41 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
You can thank the use of impact wrenches for that mess , just buy aftermarket chrome replacements unless you really want to buy new wheels .
Re: Crappy design on a Mopar [Re: JohnRR] #3153757
06/23/23 08:45 AM
06/23/23 08:45 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Impacts, massive over torque, and the fact that fractional size sockets will fit, but are just a little too big which catches just the crown of the lug nut and literally tries to peel the cover off the inner nut. If the correct metric deep well socket along with the correct torque were used, we would have a lot less trouble with them. It wouldn't eliminate the problems because it is a $hitty design, but would help enormously.
Most of these wheel lugs are spec'd to torque in the 100# to 140#. We frequently see torque in the 250+# range.
twocents
Master, again and still
Re: Crappy design on a Mopar [Re: DaveRS23] #3153761
06/23/23 08:49 AM
06/23/23 08:49 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
too many uggga uggas
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Crappy design on a Mopar [Re: bigdad] #3153792
06/23/23 11:12 AM
06/23/23 11:12 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
LOL! Mine goes budda budda.
Re: Crappy design on a Mopar [Re: 6PakBee] #3153830
06/23/23 01:23 PM
06/23/23 01:23 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I take them off and install by hand. Impact likes to destroy them.
Re: Crappy design on a Mopar [Re: mopars4ever] #3153839
06/23/23 01:41 PM
06/23/23 01:41 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ Agree - if I'm feeling lazy, I'll use my battery-powered impact gun set to "weak".
IIRC, GM did that cap-thing on their lug nuts in the '70s.
Just did all 6 tires on my Dually, which has Alcoas and stainless lug nut caps.
They pop right off, but oddly enough I've never lost one.
(Knocking on wood, lest I just jinxed myself)
Re: Crappy design on a Mopar [Re: topside] #3153848
06/23/23 02:40 PM
06/23/23 02:40 PM
moparx Offline
moparx  Offline
i get a chuckle out of the plastic "screw on" nut covers [usually black, although i have seen some "chrome" ones as well] that guys try to use an air gun to remove them, but forget which way is "lefty-loosey" on the gun switch. laugh2
beer
Re: Crappy design on a Mopar [Re: moparx] #3153864
06/23/23 03:47 PM
06/23/23 03:47 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Every time I bought a car or truck with those lug nuts on it, one of the 1st modifications on the vehicle was to replace them all with real lug nuts. The best money I've spent, one time and your usually good for the life of the vehicle.
I've had them round off before. I usually drill the stud out to remove the unremovable lug. Start with a small 1/8" bit (I buy cheap new bits that i only expect to use a few times), keep it as centered as possible and as straight as possible. The small diameter drill bit usually cuts a lot faster with a lot less pressure required. Then step up to a bigger, then a bigger bit bit until you reach the stud diameter (usually about the 3rd bit in the hole). When the last drill gets to the bottom of the nut, they usually fall off. Then you remove the wheel, the brake drum or rotor, and replace the stud and all the lug nuts. I have not screwed up a wheel since I started drilling out the stud.
You have to be more careful ordering lug nuts these days, a lot of aftermarket lug nuts are the same shell covered crap.
Re: Crappy design on a Mopar [Re: poorboy] #3153888
06/23/23 06:19 PM
06/23/23 06:19 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Here in the rust belt, we get the same results but a different cause. The actual nut rusts and swells up under the cap. Now it's an in-between size.
Same solution, solid lugs.
Angry white pureblood male
Re: Crappy design on a Mopar [Re: ruderunner] #3153939
06/24/23 12:53 AM
06/24/23 12:53 AM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
Well, every time I hook up my trailer to my 2020 Ram, I cuss at the SOB who decided that the hook points for the safety chains needed to be tucked several inches up and forward from where they were on my 09. It's easier to find detailed nuclear weapon designs on the internet than it is to get at these things.
Re: Crappy design on a Mopar [Re: Greenwood] #3153958
06/24/23 08:14 AM
06/24/23 08:14 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Re: Crappy design on a Mopar [Re: JohnRR] #3153968
06/24/23 09:31 AM
06/24/23 09:31 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I tried the chrome lug nuts and the cheap china chrome peels off after some use. Maybe a better quality nut is my answer?
Re: Crappy design on a Mopar [Re: mopars4ever] #3153986
06/24/23 11:06 AM
06/24/23 11:06 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i think i have McGard plated lug nuts on my 08 mustang.
i have swapped the wheels at least 50 times when switching to the drag wheels for racing.. i use torque sticks on my impact wrench when installing.
haven't had any problems with the chrome peeling.
perception is 90% of reality
Re: Crappy design on a Mopar [Re: Mr T2U] #3154130
06/25/23 08:19 AM
06/25/23 08:19 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
McGard lug nuts are guaranteed to not peel or rust. I bought some of them back in the 80's and was very satisfied with them.
Re: Crappy design on a Mopar [Re: BadMoonRacer] #3154186
06/25/23 03:29 PM
06/25/23 03:29 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Maybe I am seeing it wrong, but it looks like there is an alignment shank below the tapered seat, and at least one has been bottomed out ... not to say the crappy stainless or whotever covers is a good idea ...
My Mustang uses these worthless things too.
A set of Mcgards is on the bench.
I had a 66 Charger, don't remember it having a shanked lug.
It takes gasoline to interest me.
Re: Crappy design on a Mopar [Re: VL21] #3154243
06/25/23 09:37 PM
06/25/23 09:37 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I suspect like most bad ideas, these shell encased lug nuts were probably a cost cutting deal.
The actual lug nuts are undersized slightly, which probably makes them cheaper, then they get encased with thin stamped stainless steel shells, so there is no chroming costs, and they look great before they get killed and holding the wheels on. There would be no warranty issues because any damage could be blamed on improper torque, and there would be no way to disprove that. If they saved a penny per lug, look at the annual cost savings in a year for just the number of vehicles with those lug nuts. These shell nuts started showing up in the late 70s or early 80s. That would be a pretty big pile of pennies in each car company's pockets.
Re: Crappy design on a Mopar [Re: poorboy] #3154251
06/25/23 10:07 PM
06/25/23 10:07 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Not sure why this is new to anyone....we've had these chrome capped lugs around since the 80s(EVERY manufacture uses them) Rust forms on the steel nut under the chrome cap. Normally a 19mm or 3/4"......chisel the chrome cap off(simple in seconds) and a 18mm slides right on....I've done 1000s of them.
