Transmission pan marks...
#3152888
06/19/23 11:38 PM
06/19/23 11:38 PM
Posts: 4,789 Star Idaho
67vertman
Star Idaho
I took off my transmission pan to change the filter and fluid. When I cleaned it, I noticed what looks like hammer marks on the inside. The outside does not appear to be damaged in a way that it would require this type of hammering.
Thoughts?
My Monster are real!
Living within your means makes life pretty easy.
Re: Transmission pan marks...
[Re: Fat_Mike]
#3153058
06/20/23 01:49 PM
06/20/23 01:49 PM
67vertman
Star Idaho
Are those new marks, or is this the first time you've removed the pan? The first time I have taken it off.
[Re: poorboy]
#3153082
06/20/23 04:00 PM
06/20/23 04:00 PM
67vertman
Star Idaho
I'm betting at some point in its life that center got pushed up, and it was removed and beat back to close to where is is suppose to be. The person that hammered it back in place wasn't too concerned about appearance. That's what I was thinking, but the outside shows no signs of serious damage, like it hit a boulder or something. They hit it pretty hard, to leave those marks and they are not consistently spaced for dent removal. I put a straight edge along the mating surfaces and they are straight, so I painted it and plan on reinstalling it. Just strange to find. There was very little sludge
[Re: Mr PotatoHead]
#3153168
06/20/23 08:23 PM
06/20/23 08:23 PM
67vertman
Star Idaho
Post a pic of the other side. Here you go.
[Re: topside]
#3153190
06/20/23 09:34 PM
06/20/23 09:34 PM
Posts: 10,619 Freeport IL USA
poorboy
Freeport IL USA
I suspect it was one of those "Oh crap, pull it off, beat it back out, and get it back on, we got to go" repairs.
We had one of those events on our dirt track car once. Got tangled up with someone and got the trans pan smashed pretty bad. We got the car put back together, then dropped the pan, set it on the ground, and flattened it out with about 5 or 6 swings with the BFH while it still had ATF in it, through some gasket maker over the gasket and stuck it back on. Never even lost much fluid. The next week we dropped the pan, changed the filter and gasket, and put it back together. At the end of the year the car was sold for parts. Maybe you got our old trans...
[Re: poorboy]
#3153215
06/20/23 11:37 PM
06/20/23 11:37 PM
Posts: 3,098 N.W. Florida
Fat_Mike
N.W. Florida
And just add: I haven't seen everything, but I just can't imagine how a transmission failure could cause that damage. But also, if it seals run it...
