Re: 727 Tailshaft Housing Removal (In Car)
[Re: Mopar.70]
#3152712
06/19/23 02:15 PM
06/19/23 02:15 PM
Posts: 25,982 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Before you blame the gasket, be sure the leak doesn't originate at the infamous rear band lever pin.
[Re: Mopar.70]
#3152718
06/19/23 02:38 PM
06/19/23 02:38 PM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
Yes, you can easily remove it in the car. Floorjack under the trans pan, remove the driveshaft, crossmember, and trans mount from the housing. Disconnect the speedometer cable, remove the speedo gear, remove the two screws holding the access plate under the trans mount to get to the snap ring. Remove the housing to case bolts...then expand the snap ring while sliding the housing off.
[Re: A727Tflite]
#3152725
06/19/23 02:57 PM
06/19/23 02:57 PM
Posts: 250 Cent, OH
Mopar.70
Cent, OH
Thanks guys, no speedo gear in it, it's plugged. Originally I thought it was the fittings at the rear line, replaced those and re-fired yesterday, seems it's coming from that gasket around and just left of the lower bolt. Had no leaks initally upon first fire of the car and backing in and out of the garage, went to track for first test and tune and with pressure on a run it developed the leak. After new fittings on the AN hose that area and the area around the fitting was dry, In my opinion the bolts from tail shaft housing to case were not very tight, and fluid leaked at the gasket, even snuggin them up it still dripped a small bit yesterday on a test fire. I've always felt like once trans fluid starts somewhere, the only way to seal it 100% is to fully clean and re-seal 100%. I will inspect the rear line tapped area again as well thanks!
[Re: Mopar.70]
#3152734
06/19/23 03:13 PM
06/19/23 03:13 PM
Posts: 34,950 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I had Cope build a transmission , it leaked on the top two tailshaft bolts or I thought it was .. tunrs out , he stripped all the bolts out and instead of fixing it right , he blobbed on a bunch of silicone and stuff the bolts in .. hack
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: Mopar.70]
#3152741
06/19/23 03:33 PM
06/19/23 03:33 PM
John_Kunkel
Rio Linda, CA
If you have to remove the tail, put the shifter in Park and turn the driveshaft until you feel it engage in park before you start the job...this will make it easier to remove and reinstall the housing.
[Re: Mopar.70]
#3153027
06/20/23 12:19 PM
06/20/23 12:19 PM
Posts: 2,119 Byron, NY
W.I.N. Racing
Byron, NY
Its pretty straight forward...I've done it too many times... once with water running in my collar and out my pant leg
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Cab_Burge]
#3153184
06/20/23 09:21 PM
06/20/23 09:21 PM
Posts: 250 Cent, OH
Mopar.70
Cent, OH
So before tearing it all down, I took the previous advise to coat with baby powder. Everything is fresh and brand new, so wiping down before was a breeze. So did that, applied a coat as best I could to the entire rear area. Ran the car in neutral for a bit, no leaks. Ran it again for a bit longer, no leaks. Ran it a 3rd time and finally got some heat starting and it leaked. Turns out it's coming out the vent tube which is just above the rear line port. Was still showing high on dipstick, so I took 2 quarts out. Then it no longer registered on the dipstick, and while running I added half a quart. Jumped in and came up on the converter in reverse (told this was the highest pressure) and leaked out the vent again. So, tomorrow going to try a factory dipstick and see if I can get an accurate fluid level. Have a locking aftermarket one in it. It doesn't leak a drip while sitting, so starting to rule out the gasket and I'm thinking fluid level is to high.
[Re: moparx]
#3153206
06/20/23 10:57 PM
06/20/23 10:57 PM
W.I.N. Racing
Byron, NY
... once with water running in my collar and out my pant leg that happened to me once............ i missed my mouth with the beer can........ are you sure that didn't happen to you ? [just funnin' with ya ! ] Nope it was a parking lot in Reading PA... fortunately (depending on how you look at it) we got rained out so I had time to fix it...was laying under my race truck, under a street light during a rain storm. Thank goodness for youth!
