Control Arms for a street car? #3152389
06/17/23 08:45 PM
06/17/23 08:45 PM
Alberta Canada
PossessedDuster Offline OP
Alberta Canada
Are any of the aftermarket upper control arms worth it for a street cruiser?
I have a 67' Belvedere II with a built 440. Other then upgraded sway bars front and rear and a Borgeson steering box the steering/suspension is stock. Is there much value for me in upgrading the control arms? The reason I am contemplating it is when on the highway I notice that the car gets pulled into the ruts easily and I thought more caster might help with this.
Re: Control Arms for a street car? [Re: PossessedDuster] #3152440
06/18/23 06:41 AM
06/18/23 06:41 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Did you read the post right below yours?
hope you aren't running bias plies
Re: Control Arms for a street car? [Re: Sniper] #3152511
06/18/23 01:43 PM
06/18/23 01:43 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ Yup - 1st question: bias ply tires ? They'll follow any ruts or uneven surface.
Night & day difference swapping bias to radial with no other changes.
As for the aftermarket upper arms, I haven't found them necessary for my street cars using radial tires.
Generally, more caster will be better to drive straight, and I try to get about 5 degrees with the stock stuff if possible.
FWIW, my drag car had Jack Arnew's altered OEM upper arms (widened), and about 7 degrees caster, and it went straight as a string even on bias plies.
The steering wheel would unwind with a vengeance after turn-outs, but no biggie vs stability @ 130 or so.
That said, it was never street driven, and track vs street surfaces differ.
Re: Control Arms for a street car? [Re: topside] #3152563
06/18/23 09:39 PM
06/18/23 09:39 PM
Alberta Canada
Alberta Canada
Radial tires. Nothing Fancy just some 15" M/T street tires I think they are actually a Cooper Cobra.
With the vinyl bench seat I'm not looking to corner carve. How much caster can you generally achieve with a stock set-up? When I bought the car it had manual steering and I swapped over to the power borgeson set-up so I imagine the alignment was set up for negative caster
Re: Control Arms for a street car? [Re: PossessedDuster] #3152641
06/19/23 10:32 AM
06/19/23 10:32 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The max amount available "stock" might vary a bit by car, but seems around 3 deg positive can be obtained.
Check out "Moog problem solver".
In any case, sounds like you need a good old-school alignment guy.
Re: Control Arms for a street car? [Re: topside] #3154112
06/25/23 01:00 AM
06/25/23 01:00 AM
Alberta Canada
Alberta Canada
I have the name of a local shop most of the old car guys go to so I will chat them up soon.
For my use are the moog problem solvers worth the effort?
Re: Control Arms for a street car? [Re: PossessedDuster] #3155484
06/30/23 07:40 AM
06/30/23 07:40 AM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
On mine I found, that when I used the offset control arm bushings it pushed out the upper part of the tire giving undesirable camber so I had to shim out the lower balljoint along with the offset upper bushings to get things where I wanted them.
But yes all worth it.
