small diesel swap? #3152097
06/16/23 05:21 PM
06/16/23 05:21 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
I got a friend with a "man lift" and it has a small diesel 49HP naturally aspirated and it looks like it could be a totally self contained unit that would easily fit under the hood of my 93 dakota 2wd... I know people swap these small diesels into stuff but what do I do about a transmission? I would ultimately like to put it behind a NV3500 but if I did it soon I would just have to keep the auto. How do these guys atatch them to regular old transmissions? This could be the ultimate run around truck for me and with a small turbo I would think a few more HP would not be hard to get. Also if I don't end up with this particular engine is there a source of readily available engines like this that I should be looking into? I rarely ever feel the need to go over 70 MPH so I figure the power would be livable. Just got the wheels turning in my head when I saw how simple that engine was....
Re: small diesel swap? [Re: HotRodDave] #3152098
06/16/23 05:37 PM
06/16/23 05:37 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Most of those small diesel swaps use Cummins 4BT's which are found in old bread trucks and other delivery vehicles as well as things like Bobcats, etc.. There are adapters available for virtually any transmission. The downside ... those 4BT's are NOT cheap. You could do a Gen 3 hemi swap for less! As for the engine you mention, I'd suggest you do some Google searching.
Re: small diesel swap? [Re: Stanton] #3152101
06/16/23 06:03 PM
06/16/23 06:03 PM
GA
roadrunninMark Offline
GA
There are a number of VW alh swaps (99.5-04 Jettas, some Passats, and the hatchback model) too. I have an 01 Jetta diesel and it is a great little engine. I have the euro 6 speed behind it too so I get about 55 mpg highway real easy.
Re: small diesel swap? [Re: roadrunninMark] #3152114
06/16/23 07:11 PM
06/16/23 07:11 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Daughter's VW diesel bit the biscuit ... at 607,000 kms.
Re: small diesel swap? [Re: Stanton] #3152120
06/16/23 07:27 PM
06/16/23 07:27 PM
Kalispell Mt.
Kalispell Mt.
Yes it seems the 4BT would be easy, just put my trans guts into a 618 case and it would bolt right up but man those are way to expensive to justify for this swap. Also they are very heavy, much heavier than the ole 318 and noisier than this little bity diesel.
No way on the VW, I have had terrible luck with those for some reason.
Re: small diesel swap? [Re: HotRodDave] #3152128
06/16/23 07:59 PM
06/16/23 07:59 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Here is a build thread for a early 90's dakota that someone swapped a 4bt 47rh combo into. IIRC 4bt will take the same adapter as the 5.9 6bt.
https://www.4btswaps.com/threads/94-dakota-4bt-swap.7949/
Re: small diesel swap? [Re: HotRodDave] #3152222
06/17/23 07:46 AM
06/17/23 07:46 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Is it a Mitsubishi 49.5 hp diesel like used in the GA-500 tractors?
https://www.manytractors.com/farm-tractor/mitsubishi/models
The Mitsu “forklift diesel” was used in late 1970s Dodge pickups with manual transmissions,
and my fuzzy memory that it was also used in Chrysler South American assembled cars
wiki
The 1978 models also saw the introduction of the first diesel powered Dodge pickup truck. Available as an economy choice in light-duty trucks and B-series vans was Mitsubishi's 6DR5 4.0 L inline six-cylinder naturally-aspirated diesel, rated at 105 hp (78 kW) at 3500 rpm, and ~230 N·m (~169 lb·ft) at 2200 rpm. The diesel used standard Dodge manual and automatic transmissions via specially made adapter plate which had the LA V8 bolt pattern. This rare factory option, VIN code H, was the result of fuel crisis and the collaboration of Chrysler and Mitsubishi.[9] The engine, while being trustworthy and having far better economy than any other engine in the Dodge lineup at the time, suffered from low power output and was considered to be underpowered by American standards, even though it was previously used in the Japanese 3.5-ton cab-over Mitsubishi T44 Jupiter Truck and in industrial applications. Because of the low sales, it was phased out quickly, and as a result, it became practically a single-year specialty.
Re: small diesel swap? [Re: 360view] #3152226
06/17/23 08:14 AM
06/17/23 08:14 AM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
Biggest problem with an industrial diesel is that they are setup to run at constant speed and don't take well to changes in throttle.
More precisely it's the injection pump that's setup that way. So to make it a drivable engine you're going to change the pump.
Angry white pureblood male
Re: small diesel swap? [Re: 360view] #3152283
06/17/23 12:46 PM
06/17/23 12:46 PM
USA
3
360view Offline
360view  Offline
3
USA
Dodge Dakotas built in Brazil years ago had a factory option of a Brazilian built Detroit Turbo Diesel, but that engine had head gasket troubles.
https://www.4btswaps.com/threads/brizilian-turbo-diesel-dakota-pickup.22018/
Re: small diesel swap? [Re: HotRodDave] #3152434
06/18/23 01:53 AM
06/18/23 01:53 AM
Alberta Canada
PossessedDuster Offline
Alberta Canada
Cummins 2.8 crate engine would be the way to go
https://www.cummins.com/engines/repower
Re: small diesel swap? [Re: PossessedDuster] #3152436
06/18/23 03:57 AM
06/18/23 03:57 AM
Guitar Jones Offline
And people think the 4BT is expensive?
Re: small diesel swap? [Re: Guitar Jones] #3152439
06/18/23 06:36 AM
06/18/23 06:36 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
I don't think this is an exercise on how to save money. The devil is in the details. twocents
Re: small diesel swap? [Re: 360view] #3152469
06/18/23 09:21 AM
06/18/23 09:21 AM
USA
3
360view Offline
360view  Offline
3
USA
The Mazda B2200 mini pickup of the 1980s had a Perkins diesel of 60 HP and a manual trans.
I have had several Perkins diesels in equipment and found them durable but very, very hard to start in cold temperatures.
https://barnfinds.com/sweet-oil-burner-1984-mazda-b2200-diesel/
Re: small diesel swap? [Re: redraptor] #3152490
06/18/23 12:12 PM
06/18/23 12:12 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
It would take a hell of a lot of driving to ever see a payoff for a diesel swap using used components, let alone buying a new engine. Price of diesel now negates most of the fuel savings.
Not trying to hijack this thread, but a CNG bifuel conversion is the way to go if savings on fuel costs is the primary concern and there is access to the CNG in your normal driving routes.
Re: small diesel swap? [Re: mgoblue9798] #3152501
06/18/23 12:58 PM
06/18/23 12:58 PM
USA
3
360view Offline
360view  Offline
3
USA
ultimate low cost fuel option, widely used in 1929 to 1946 difficult period
https://en.wikipedia.org/wiki/Wood_gas_generator
but, every few thousand miles you have to clean up the byproduct tar from every nook and cranny in fuel lines and carburetor jets.
Works best with least tar using the nearly pure carbon from charcoal, petroleum coke, steel-making coke, etc
sample quote
A 2010, Mother Earth News article discussed and showed pictures of a wood gas powered engine installed in a pickup truck.[17] As part of the BBC science series "Bang Goes The Theory", a Volkswagen Scirocco was converted to a design by Martin Bacon to run on used coffee grounds, and after its build in 2010 was driven solely on coffee from London to Manchester successfully. Part of the team are now working on a more advanced design leaning towards top speed as opposed to range.
On September 14, 2011, at the Bonneville Salt Flats a truck modified with a wood gas powered engine set a new world speed record for vehicles powered by wood gas with a speed of 73 mph.[18]
end quote
Re: small diesel swap? [Re: mgoblue9798] #3152518
06/18/23 03:01 PM
06/18/23 03:01 PM
Kalispell Mt.
Kalispell Mt.
An older small mechanical injected diesel about 50-75 HP should get 50 MPG and be capable of running at least partially on used oil from my repair shop. I had a 93 cummins ram I routinely ran on used oil from the honda dealer I was working at for several years.
Re: small diesel swap? [Re: 360view] #3152520
06/18/23 03:15 PM
06/18/23 03:15 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Detroit Diesel 6V53T wish I knew how to work on one.
Best sounding engines ever!
Re: small diesel swap? [Re: RTSE4ME] #3152673
06/19/23 12:27 PM
06/19/23 12:27 PM
Kalispell Mt.
Kalispell Mt.
Super charged 318 V6 that makes less HP and weighs twice as much as existing 318 V8?
Re: small diesel swap? [Re: HotRodDave] #3152709
06/19/23 02:14 PM
06/19/23 02:14 PM
USA
3
360view Offline
360view  Offline
3
USA
Is your little diesel a
Deutz D2.9L4 49 hp ?
from
https://www.jlg.com/en/equipment/en...pic/400-series/400s-telescopic-boom-lift
Re: small diesel swap? [Re: 360view] #3152833
06/19/23 08:34 PM
06/19/23 08:34 PM
Kalispell Mt.
Kalispell Mt.
from
Looks just about exactly like it
