-8 or -9 NGK at 15-1
#3152259
06/17/23 11:08 AM
06/17/23 11:08 AM
Posts: 9,883 MI, usa
dvw
MI, usa
Been running NGK-9 (R5671-9) in my 15-1, Indy -1 heads, flat top piston, 57cc chamber. Renegade Pro 114 fuel 7200 rpm max. Any advantage to running the projected tip? Also not really sure if it needs -9 or-8. I have both -8 extended (R5672-8) and normal tip (R5672-8) in stock. I'd have to get more -9's Thanks Doug
Re: -8 or -9 NGK at 15-1
[Re: dvw]
#3152270
06/17/23 12:13 PM
06/17/23 12:13 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Do you have room for the projected tip plug? As for heat range what does the plug look like? I have run -8's at 15-1. But it is combination dependent whether it can be tolerated or not.
[Re: moparacer]
#3152497
06/18/23 12:47 PM
06/18/23 12:47 PM
Al_Alguire
Las Vegas
If you have the room, and it appears you do I would go with the extended tip.
[Re: Al_Alguire]
#3152516
06/18/23 02:11 PM
06/18/23 02:11 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Doug, i have run -9 exclusively in 15.25 compression motors, 5672-9 in both 550 with indy 440-1 heads, and 572-13 heads. The 572-13 combo has a dome that requires indexing the ground strap between 10 and 2 oclock. I have no problem getting good readings off the plugs running methanol. Those combos made 926 hp and 982hp respectively.
[Re: dvw]
#3152620
06/19/23 08:39 AM
06/19/23 08:39 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
FWIW...I ran NGK R5671A-8 (4554) plugs in my 14.5:1 dome piston Indy SR headed 446" wedge w/ no issues. Ran on Renegade 112 fuel.
