1" pullout for driveshaft measurement? #3151199
06/13/23 01:11 PM
06/13/23 01:11 PM
BDW Offline OP
BDW  Offline OP
Curious why 1" is used for the measurement when ordering a driveshaft?
I know there's suspension moment, but for a typical car that DS angle is almost flat at rest.
So any movement of the suspension would only pull the driveshaft out more.
I get that a several pinion angle downward will have some affect, but not much.
So is it better err on a longer DS, 1/2" pulllout?
Reason I ask, is I had a drive line vibration, putting in a longer slip yoke helped a ton.
The pullout now is 1.5", and I still have some vibration.
Don't want to spend $600 and not get it right.
Thx
Re: 1" pullout for driveshaft measurement? [Re: BDW] #3151208
06/13/23 01:38 PM
06/13/23 01:38 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
When i put my car together(many moons ago) The driveshaft guy asked me to put my car on a drive on hoist and measure from the trans output shaft tip to the center of the ujoint saddle on the diff. I gave him that measurement and the slip yoke and he built me a shaft. It's been in there 25+ yrs with zero issues. Could your vibration be caused by pinion angle and not the shaft? I changed ride height at one point and developed a vibration on light accel..... a shim under the leafs cured it.
Re: 1" pullout for driveshaft measurement? [Re: Dcuda69] #3151216
06/13/23 02:02 PM
06/13/23 02:02 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Keep in mind the suspension goes up as well.
Ive had several Drive.Shafts built. And always use the 1inch out measurement. No problems
Re: 1" pullout for driveshaft measurement? [Re: BDW] #3151251
06/13/23 03:50 PM
06/13/23 03:50 PM
IL
8
83hurstguy Offline
83hurstguy  Offline
IL
When I ordered my new driveshaft from Mark Williams, they will go down to 3/4" slip yoke travel (and their tech support recommended that). I think I ended up on the short side of the 3/4" due to rounding measurements.
I converted from a driveshaft with around 1-5/8" slip yoke travel and noticed a vibration improvement from the 1-5/8" to the 3/4". Leaving the U-joint hanging out there too far can be felt, at least with a four speed it can be felt in the shifter. The MW tech confirmed it's a common issue, too. People get worried about the output shaft seal dust boot, make the driveshaft too short, then have a vibration issue.
Re: 1" pullout for driveshaft measurement? [Re: BDW] #3151394
06/14/23 02:50 AM
06/14/23 02:50 AM
Cab_Burge Online work
Cab_Burge  Online Work
The old Mopar drag seminars would say to push it in all the way and slide it out 3/4 inch with all the weight on the suspension including the drivers weight and use that measurement from center to center on the length for the U joint cups centers, regardless of which tranny yoke length you had scope up
That method has work well for me and a lot of others racers on here wrench up
Re: 1" pullout for driveshaft measurement? [Re: BDW] #3151406
06/14/23 07:45 AM
06/14/23 07:45 AM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
You don't mention your setup but if the factory built the same body style with the same transmission and rear end, the easy way to get it right is to use the length from the FSM.
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: 1" pullout for driveshaft measurement? [Re: Bob Stinson] #3151679
06/15/23 12:20 AM
06/15/23 12:20 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
The amount that a driveshaft actually 'slips' through full suspension travel on these old Mopars is minimal. On my '66 Dart, the difference shaft length at ride height vs full suspension droop was about 1/8"-3/16" (actually shorter at full droop). After I realized that, I now file this is the "don't overthink it" category. 3/4" of pull out at ride height is plenty.
Re: 1" pullout for driveshaft measurement? [Re: BDW] #3151739
06/15/23 11:59 AM
06/15/23 11:59 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Keep in mind that the u-joint cups are are 1"+ in diameter and the cradle in the rear yoke that they sit in is a little over half that deep, so you need at least that much in order to push the shaft forward during installation before pulling it back into the yoke. 3/4" should cover all bases.
Re: 1" pullout for driveshaft measurement? [Re: John_Kunkel] #3151806
06/15/23 03:23 PM
06/15/23 03:23 PM
BDW Offline OP
BDW  Offline OP
Appreciate the input, another question
Would changing the front yoke to 1350 from 7290 and using a conversion u-joint change the DS length?
1350 is a little larger, so maybe only 1/16 or 1/8" ?
Thx
Re: 1" pullout for driveshaft measurement? [Re: BDW] #3151831
06/15/23 04:51 PM
06/15/23 04:51 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
The two different size or different brands of front yokes might be different lengths. Best to get the yoke and then measure for drive shaft. No guessing here.
Re: 1" pullout for driveshaft measurement? [Re: GomangoCuda] #3152002
06/16/23 11:03 AM
06/16/23 11:03 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
3/4" here.
Some kind of weird pinion angle, leaf spring setup may need more.
Re: 1" pullout for driveshaft measurement? [Re: BDW] #3152005
06/16/23 11:10 AM
06/16/23 11:10 AM
BDW Offline OP
BDW  Offline OP
Thx
I’ll answer my own question on this part, 1350 has 1/16” larger cup size compared to 7290.
So 1/2 of that 1/16” would make it 0.030” longer, nothing to worry about.
I’m going 3/4” when I get around to getting this done.
Re: 1" pullout for driveshaft measurement? [Re: BDW] #3152026
06/16/23 12:23 PM
06/16/23 12:23 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Thx
True.
But the hole is bigger. The C/L doesn't move. Does a larger or smaller crank pin journal change the stroke?
Re: 1" pullout for driveshaft measurement? [Re: CMcAllister] #3152064
06/16/23 02:29 PM
06/16/23 02:29 PM
GomangoCuda Offline
GomangoCuda  Offline
Yes but is the bottomed out length the same on all yokes? Different brands, different materials, oem, aftermarket forged or billet. All the same?
Re: 1" pullout for driveshaft measurement? [Re: GomangoCuda] #3152102
06/16/23 06:07 PM
06/16/23 06:07 PM
BDW Offline OP
BDW  Offline OP
Very good question, I have 2 different yokes, 1 aftermarket cast, and a factory forged that came with the 518 when I pulled it at JY.
