Re: Next.... Durango dash
[Re: volaredon]
#3152012
06/16/23 11:30 AM
06/16/23 11:30 AM
Posts: 8,670 Buford, GA
I_bleed_MOPAR
Buford, GA
Done it twice on Dakota's for heater cores. Tedious but not too bad in my opinion. 2nd set of hands to help you set the dash out would be a plus. The first one I just cocked it back on the seats and worked around it. 2nd one I spent the extra few minutes to get it out of the way.
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: JDMopar]
#3152772
06/19/23 06:24 PM
06/19/23 06:24 PM
Posts: 2,243 ILLINOIS
volaredon
ILLINOIS
I didn't have any problem with that. I have the 360, though I did go to a junkyard and looked at a few with 4.7s, damn I'd have had to pull the engine out to get at the 4 nuts that go thru the firewall. As it was I only had an issue with 1 of the 4. I had to unscrew the trans dipstick from the back of the head to get at that one. I'm 3 days into a "5 hour" job according to Mitchell. That includes a trip to an LKQ (never again, Sunday or not) they changed their prices drastically. An automatic add of 40% for a "90 day warranty" and the b!tch tried to charge me separate for the heater core, the evaporator and 5 blower motors (each actuator is a "blower motor") so i went outside and pulled off the wiring harness and left the rest on the counter. For that wiring harness, a air cleaner assembly and a factory Durango radio it cost me $84 to get outta there. I was blown away. If I would have taken that "heater box ASSEMBLY" it would have been $200 just for that. I just wanted the housing because of a couple of cracks, which I JB welded instead, (which accounts for most of the time spent) and because I have been fighting a "won't blow air out the floor vents" for years. I had already bought new evaporator and new heater core, and new actuators. I pd $31 ea for the actuators at O'Reilly's the junkyard would have wanted $23 each for their used ones. Screw that. I wanted the wiring harness because I've replaced the blower motor resistor pigtail so many times I was left with nubs.... And had to cut the connector for the blower motor when I replaced that the first time about 5 years ago. Everything on mine is brand new now except the plastic housing itself. What a rube Goldberg setup for the linkage to open the various blend doors on that thing jeez..... I've fought with that over the years on mine too (another reason I wanted to start with a different housing)
