Repop 15 x 7 Rallys
#3151055
06/13/23 01:26 AM
06/13/23 01:26 AM
Posts: 821 On the open road
Hrtbkr
On the open road
Hi Is anyone running US Wheel repops? Have you had any issues? I'm in need of a couple of 15 x 7 Rallys for my new project. People were asking breathtaking prices for factory originals at the last swap, I think aftermarket is the way to go. Thanks
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
Re: Repop 15 x 7 Rallys
[Re: Hrtbkr]
#3151282
06/13/23 05:54 PM
06/13/23 05:54 PM
Posts: 8,396 Highland, MI.
Sunroofcuda
Highland, MI.
That right there should tell you why good OEM ones are going for so much. It'll be interesting to hear some replies here with stories of the reproductions.
[Re: Hrtbkr]
#3151345
06/13/23 08:22 PM
06/13/23 08:22 PM
Posts: 4,453 Morristown Tn.
71birdJ68
Morristown Tn.
I think mine might be US Wheel, I hate them, they don't sit flush with the hub, so I have to pull it down with the lug nut. I think maybe all of the china wheel have some sort of issue.
[Re: Neil]
#3151377
06/13/23 10:32 PM
06/13/23 10:32 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Yes on the Wheel Vintiques back in the day - Having to scuff perfectly good powder coating so you could spray the proper Silver Argent
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#3151427
06/14/23 10:18 AM
06/14/23 10:18 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Mine are well over 25 years old sprayed in the proper silver and over 55,0000 miles with no issues ever.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3151438
06/14/23 10:53 AM
06/14/23 10:53 AM
Posts: 20,788 A collage of whims
topside
A collage of whims
Since the late '80s, I've bought maybe a dozen sets of repro Mopar wheels - Rallyes & Magnums - for my A & B bodies. Never had a runout, straightness, or balance issue until a few years ago, which happened to be some Magnums from Coker after they bought Wheel Vintiques & Specialty. One of the 4 was visibly wobbly, and after proving so with a readout from my tire shop, they replaced it. I always thought there's be a fixture so the spider is "square" with the barrel when welded, but apparently not, or it wasn't checked. I asked them about QC and the guy at Coker said they don't check dimensional quality. Last set I bought came from Holley via Ebay - straight, radial runout was about .060 on a couple, but they balanced and have driven fine. Bottom line: check them before mounting tires.
[Re: 71birdJ68]
#3151497
06/14/23 02:11 PM
06/14/23 02:11 PM
Posts: 19,408 north of coder
moparx
I think mine might be US Wheel, I hate them, they don't sit flush with the hub, so I have to pull it down with the lug nut. I think maybe all of the china wheel have some sort of issue. unfortunately, cranking them flush to the mounting surface can cause some "fun" when removing them if the center bore diameter is too small, causing a light press fit. i have seen this happen on factory wheels that had too much powder coat applied. after lots of "words not to be said around women and children" being used, beating on the back side of the wheel/tire with a sledge, then finally loosening the lugnuts a couple turns and slowly driving in a circle while slamming on the brakes several times, the wheel finally popped loose from the hub. if the center bore of the wheel does not allow it to fit flush to the hub mounting surface, it has to be opened up the smallest amount necessary for it to do so. if that means the removal of powder coat, chrome, or just wheel material, so be it. just my opinion. your mileage will vary.
[Re: bee1971]
#3151713
06/15/23 08:29 AM
06/15/23 08:29 AM
Posts: 28,599 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Yes on the Wheel Vintiques back in the day - Having to scuff perfectly good powder coating so you could spray the proper Silver Argent I kinda have a small wheel collection here. Quite a,few sets of 15x7 and 15x8.Wheel Vintques here. A,quick scuff prime and paint was all they needed. Checked runout and balanced all were good to go. Were good as factory 15x6.5 and 15x7 rallies to me. Only downside on 15x8 was trim rings gap, but need 8 inch wide for large Drag Radials Also have factory 15x6.5, 15x7 and a pair of 15x8 Ram Charger Wheels tanks You-Pull-It. I did not want to trust new China wheels. Like posted above the new Repops are hit and miss My wife lets me sell nothing. Says we may need them one day. I would get older Wheel Vintques or factory and pay the extra
[Re: mopars4ever]
#3153714
06/23/23 01:02 AM
06/23/23 01:02 AM
Hrtbkr
On the open road
I ended up buying a couple of Wheel Vintiques. I had them spun and they were no better (or worse) than the OEM pair I'm also using. I'm goin to have to paint them to match the other wheels, so the finish doesn't matter. Thanks for all the advice
[Re: moparx]
#3153889
06/23/23 06:19 PM
06/23/23 06:19 PM
Posts: 10,136 A Red State
SNK-EYZ
A Red State
i'm curious if anyone has spun original wheels, then the reproductions, and checked how balanced they are ? I spun the repops and pair of original wheels for the original poster and the wheels had the same amount of runout. About.030-.050 (thousandths) on both the repops and original wheels.
[Re: SNK-EYZ]
#3154093
06/24/23 10:19 PM
06/24/23 10:19 PM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
Bought a set of US wheels 15x7s about 2 years ago. They looked great but the welds on the back were terrible. About 30-40 percent missed the intended location joining the hub to the rim. I sent them back and bought a set of originals.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
