1971 Charger R/T Door Stripe Location #3151300
06/13/23 06:54 PM
06/13/23 06:54 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Hi Everyone,
I am trying to locate the door stripes on my 1971 Charger R/T.
Do they sit entirely within the depression? Or are they up on the curve/rise to the plane of the door at all?
It's weird, the curve of the stripes I have seems to be little tighter than the curve of the depressions. The instructions say to put the stripes 1/8-inch away from the edge of the depression, but if I set them at that location in the middle of the stripe, the tops and bottoms are farther than 1/8-inch away from the edge, if that makes any sense.
Any advice or close up pictures are appreciated!
Thank you.
Greg
Re: 1971 Charger R/T Door Stripe Location [Re: GregY] #3151408
06/14/23 07:49 AM
06/14/23 07:49 AM
MA
steve70 Offline
steve70  Offline
MA
hope this helps
1970 Challenger T/A 4 speed
Re: 1971 Charger R/T Door Stripe Location [Re: steve70] #3151425
06/14/23 09:58 AM
06/14/23 09:58 AM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Those look like a BEAR to install... Look nice!!
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 1971 Charger R/T Door Stripe Location [Re: JMCFAN] #3151441
06/14/23 10:58 AM
06/14/23 10:58 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
So my two comments are 1) I still can't really tell if those are entirely in the flat of the depression, but 2) more importantly, your stripes look a lot more vertical than the ones I have do, mine have a LOT of curve to them.
Nice car BTW, and JMCFAN I think you are correct, I am only hoping/wishing to get the door stripes on by myself, I would probably hire a pro to put the whole decal package on!
Re: 1971 Charger R/T Door Stripe Location [Re: GregY] #3151500
06/14/23 02:17 PM
06/14/23 02:17 PM
MA
steve70 Offline
steve70  Offline
MA
There's a lot going on with the side stripes so it might be best to hire someone experienced.
Re: 1971 Charger R/T Door Stripe Location [Re: steve70] #3200002
12/25/23 05:29 PM
12/25/23 05:29 PM
Chilly Northern, Minn.
71 Charger R/T Offline
I think you may have the passenger side stripes upside-down on the driver's side (by looking at the curvature of the stripe).... Yes, they should be about an 1/8 of an inch from the leading edge of the depression. My original unmolested doors had them between 1/8 to 1/4 of an inch from the edge.
Re: 1971 Charger R/T Door Stripe Location [Re: 71 Charger R/T] #3200003
12/25/23 05:48 PM
12/25/23 05:48 PM
If you look closely at the top (silhouette) of the stripe and bottom of the stripe, you'll notice the top has a little flat to it and the bottom is more of a radius.
Re: 1971 Charger R/T Door Stripe Location [Re: 71 Charger R/T] #3200141
12/26/23 07:40 PM
12/26/23 07:40 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Those are great pictures thank you. I got mine on, I am happy with 3 of them, the 4th one is off a little bit, but not sure it's bad enough to redo.
Greg
