Re: Factory mini starter
[Re: chargers777]
#3151407
06/14/23 07:47 AM
06/14/23 07:47 AM
Posts: 1,336 Oregon
earlymopar
Get a starter for a 2005-2008 Dodge Ram with a 5.7 and a MANUAL transmission, the automatic starter for this application is totally different and will not fit.
The manual transmission starter is a coaxial (planetary) gear reduction design, not offset like the Chrysler and Nippondenso gear reduction starters (the difference is shown below). That's why the motor housing is directly in line with the starter drive axis, making the whole starter more "compact".
Be sure and get a genuine starter with a Chrysler, Denso, or Nippondenso nameplate on it.
[Re: earlymopar]
#3151449
06/14/23 11:24 AM
06/14/23 11:24 AM
Posts: 638 Graz, Austria
DGS
Graz, Austria
The 2005+ Hemi starter does NOT work on a 440! Small block yes iirc but on a BB the solenoid hits the block!
[Re: DGS]
#3151501
06/14/23 02:17 PM
06/14/23 02:17 PM
Posts: 19,535 north of coder
moparx
The 2005+ Hemi starter does NOT work on a 440! Small block yes iirc but on a BB the solenoid hits the block! well that's something to know ! i was ready to pull the plug for two of those for my projects ! so it's still the dakota starter then, with TTI 2"/2 1/8" /3 1/2" collector headers ?
[Re: DGS]
#3151537
06/14/23 04:00 PM
06/14/23 04:00 PM
Posts: 1,545 Seattle, WA
375inStroke
Special needs person
Seattle, WA
Can confirm. When I first saw the starter, I thought too good to be true. Well, it was.
[Re: 375inStroke]
#3151560
06/14/23 05:19 PM
06/14/23 05:19 PM
Posts: 15,911 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
If you can get dimensions on the factory Dak starter you'll see it's basically a mini at much lower cost
Facts are stubborn things.
[Re: earlymopar]
#3151704
06/15/23 07:29 AM
06/15/23 07:29 AM
Posts: 1,336 Oregon
earlymopar
Sorry about this. In trying to provide a quick answer, I completely missed that this is a big block application.
[Re: moparx]
#3152645
06/19/23 10:45 AM
06/19/23 10:45 AM
DGS
Graz, Austria
The 2005+ Hemi starter does NOT work on a 440! Small block yes iirc but on a BB the solenoid hits the block! well that's something to know ! i was ready to pull the plug for two of those for my projects ! so it's still the dakota starter then, with TTI 2"/2 1/8" /3 1/2" collector headers ? Or you can do this (some fab work involved though): https://board.moparts.org/ubbthread...e-mini-starter-question.html#Post3101507
[Re: DGS]
#3152656
06/19/23 11:22 AM
06/19/23 11:22 AM
Posts: 16,837 Between Houston & Galveston TX
SattyNoCar
I ran a mini starter in my wagon for years that I pulled out of a '92 van. Only issue was this style had an adaptor for the wires that needed to be removed (easy). My wagon had a '77 440 with HP manifolds.
As much as I missed the gear reduction whine, it was really nice having to basically just bump the starter to get it to start.
John
