Crowds in tulsa #3151051
06/13/23 12:50 AM
06/13/23 12:50 AM
Kansas
Thelma133 Offline OP
Kansas
Bad fish, you out there?? How crowded is Tulsa now that Great bend and Topeka are closed? Has anyone been there recently?
Re: Crowds in tulsa [Re: Thelma133] #3151072
06/13/23 06:30 AM
06/13/23 06:30 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Topeka isnt closed. Yet. Test and tune this Friday as a matter of fact.
Re: Crowds in tulsa [Re: Thelma133] #3151144
06/13/23 11:07 AM
06/13/23 11:07 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I haven't been in awhile but it wasn't too bad last time I went for test and tune. Show up early and be ready and you can get some solid runs in before it gets busy. I can usually smash out 3-5 runs in with no line pretty easy when it opens up. My car cools off quick and is fuel injected so so it is easy to smash out passes when the lanes aren't crowded. Later in the night after an oil down or they run jrs or whatever the lines will start to back up some. Tulsa could really use someone to run the front and back of the lanes.
I might try and make it out this Friday but I have some work to get done if I am going to make it.
68 Barracuda Formula S 340
Re: Crowds in tulsa [Re: Thelma133] #3151210
06/13/23 01:40 PM
06/13/23 01:40 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Where are you at in Kansas?
Are Mo-Kan or Mid America Dragway options?
'63 Dodge 330
11.19 @ 121 mph
