Page 6 of 7 1 2 3 4 5 6 7
Re: headers glowing red at idle [Re: B1MAXX] #3150741
06/12/23 09:07 AM
06/12/23 09:07 AM
st.louis,mo.
dart games Offline OP
st.louis,mo.
hard core.carb was came with engine.never fireed.b-1 ill go back and reset 15-20.
Re: headers glowing red at idle [Re: dart games] #3150749
06/12/23 09:35 AM
06/12/23 09:35 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
You didn't buy the CARB directly from Dominic...HIS SERVICE DOESN'T TRANSLATE TO YOU DON'T BASH HIM, YOU HAVE NO RIGHT. Your issue is directly between you and the guy you purchased the engine from. This is absurd to even have to explain it.
Re: headers glowing red at idle [Re: dart games] #3150755
06/12/23 10:01 AM
06/12/23 10:01 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
car nut.thumper built the carb.why was the bleeds put in the wrong place.the motor was built correctly.next thing is should i put everything back the way it was.i didnt mention during the week i change the valve lash from 15 int,20 exhaust to 25 straight up.and that didnt fix it.but i might go change that.i dont feel i should go back in and change it back to 4 degree advanced.all that does is change the power band.should i put the power valve back in carb.i did plug it.do i put rivets in the throttle blades where i drilled them.it idles ok
How can idle bleeds be put in the wrong place? More explanation of what you found and how you changed it is needed.
Could the engine builder have made changes after receiving the carb from Thumper? Could the carb have actually been ordered for a very different engine and found its way onto yours?
Re: headers glowing red at idle [Re: HardcoreB] #3150757
06/12/23 10:04 AM
06/12/23 10:04 AM
Commerce, Michigan
EasyG Offline
EasyG  Offline
Commerce, Michigan
Yeah!
Re: headers glowing red at idle [Re: EasyG] #3150764
06/12/23 10:29 AM
06/12/23 10:29 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
So the high speed and idle air bleeds were reversed? Easy enough fix. Glad you found it.
Re: headers glowing red at idle [Re: Leigh] #3150802
06/12/23 12:04 PM
06/12/23 12:04 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Im not from Missouri but lived in Kansas for years so changing air bleeds a few thou fixed it, you are gonna have show me..If HS and idle were swapped which I doubt Dom would do as that's a pretty rookie mistake I still cant see it causing the issue. But hey what do I l know but would have to see it with my own eyes to believe it.
Re: headers glowing red at idle [Re: HardcoreB] #3150811
06/12/23 12:30 PM
06/12/23 12:30 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Exactly.
69 GTX 68 Road Runner
Re: headers glowing red at idle [Re: Al_Alguire] #3150813
06/12/23 12:36 PM
06/12/23 12:36 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Agreed, and if so wouldn't idle mixture screws still function? (and if they didn't wouldn't you start there?)
Re: headers glowing red at idle [Re: Al_Alguire] #3150814
06/12/23 12:41 PM
06/12/23 12:41 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
This. I'm betting it was a carb baseplate gasket and air bleeds. But you still can't dump this on Dom. I looked at that carb and it doesn't look like the ones he builds. He may have "rebuilt " it. He gives his time freely whenever you call him. Like most have posted glad you got it figured out.
America First!
Re: headers glowing red at idle [Re: carnut68] #3150818
06/12/23 01:01 PM
06/12/23 01:01 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
IF Dom touched it, it would have his stickers on the bowls. THAT carb, is NOT one of Dom's carbs that he builds.
Re: headers glowing red at idle [Re: JERICOGTX] #3150823
06/12/23 01:11 PM
06/12/23 01:11 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
Exacty. I have one and it flat out works.
America First!
Re: headers glowing red at idle [Re: carnut68] #3150841
06/12/23 01:39 PM
06/12/23 01:39 PM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
Looking at the pics. It doesn't look like it has billet base plate just billet metering blocks. Hard to tell.
Dom won't work on carbs with cast base plate. I think he uses all BLP parts for his builds.
No sticker either.
Re: headers glowing red at idle [Re: RTSE4ME] #3150842
06/12/23 01:41 PM
06/12/23 01:41 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
No sticker either.
Correct. All his builds use BLP parts, and Superformance gaskets. If that carb was done years ago, there is no telling how many times it's been "tweeked" by someone else...
Re: headers glowing red at idle [Re: JERICOGTX] #3150853
06/12/23 01:56 PM
06/12/23 01:56 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Originally Posted by JERICOGTX
[quote=RTSE4ME]... there is no telling how many times it's been "tweeked" by someone else...
That was my first thought but even if it had undamaged tamper tags on it, this guy didn't buy it from Dominic. So many scenarios could have happened i.e.-What if the guy who bought it from Dominic 'did him wrong' in some way. I guess I'm going thru the trouble to engage this to undo some of the character assassination AND to offer the OP another course of thinking. It'd probably do him well to rethink his words and actions if he's looking for additional tech advice here or even friendly assistance at the track.
Re: headers glowing red at idle [Re: HardcoreB] #3150857
06/12/23 02:05 PM
06/12/23 02:05 PM
MD
MD
I bet that the carb isn't one of Dom's he built or rebuilt. Maybe that's why he would not help.
Also he sends a tuning kit on all carb work done.
Re: headers glowing red at idle [Re: rickraw] #3150928
06/12/23 04:58 PM
06/12/23 04:58 PM
lino lakes, mn
Schultz62 Offline
Schultz62  Offline
lino lakes, mn
Only thing missing is a dude who knows anything about motors and tuning. My take after reading this drama is you should sell everything and take up...hmm don't know as you'd probably eff up most anything. Throwing Dom under the bus confirms you are an idiot.
Re: headers glowing red at idle [Re: Schultz62] #3150948
06/12/23 06:02 PM
06/12/23 06:02 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Well put.
Re: headers glowing red at idle [Re: rickraw] #3150977
06/12/23 07:38 PM
06/12/23 07:38 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I thought troll once he wouldn't post the crank gear pic
Re: headers glowing red at idle [Re: Schultz62] #3151048
06/13/23 12:19 AM
06/13/23 12:19 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I'm glad you said this and it took everything I had to not let this monkey have it but what a crock about blaming me for anything carb related. I really appreciate you guys sticking up for me and if I could say what I felt I would but ether way this fool has no right even owning anything performance oriented and I'm sorry this even went here....And to the OP (whatever your name is) at least learn how to type in proper sentences that look proper or even make any sense....
Re: headers glowing red at idle [Re: Thumperdart] #3151050
06/13/23 12:40 AM
06/13/23 12:40 AM
Kansas
Thelma133 Offline
Thelma133  Offline
Kansas
I bought one of Doms carburetors. He was there helping during entire installation as I had lots of questions. This guy had a car for sale and that should answer any questions about his temperament. I think he said to “POUND SAND” no less than 4 times in his ad. Weirdo.
