Zinc additive?
#3150765
06/12/23 10:29 AM
06/12/23 10:29 AM
Posts: 2,092 New Mexico
JMCFAN
New Mexico
Recent ( 1st) oil change on the roadrunner. Should I add a zinc additive?
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: Zinc additive?
[Re: EW1BH27]
#3150780
06/12/23 11:02 AM
06/12/23 11:02 AM
JMCFAN
New Mexico
It all depends on what you used already. If it was just typical conventual oil then yes. This is what my engine builder recommended and what I use. I used that on intial oil when engine was built. I just did oil change .( aprox 500 miles) Penzoil synthetic 10W30
Re: Zinc additive?
[Re: Neil]
#3151011
06/12/23 08:53 PM
06/12/23 08:53 PM
Posts: 15,871 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I use VR1 also but if your build is roller cam setup why worry about zinc?
Facts are stubborn things.
Re: Zinc additive?
[Re: larrymopar360]
#3151070
06/13/23 06:15 AM
06/13/23 06:15 AM
Posts: 1,792 Greer, SC
TooMany62s
Greer, SC
I think the problem is oil advertised today as "high zinc" simply means that oil is at or near the legal limit, which I think is around 800ppm. Back in the days before all cars had roller cams I think the amount of zinc in oils was at least double the 800 ppm number. How much zinc does a flat tappet motor need after proper break-in? I wish I knew.
Re: Zinc additive?
[Re: JMCFAN]
#3151106
06/13/23 09:34 AM
06/13/23 09:34 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
It all depends on what you used already. If it was just typical conventual oil then yes. This is what my engine builder recommended and what I use. I used that on intial oil when engine was built. I just did oil change .( aprox 500 miles) Penzoil synthetic 10W30 Yes, I'd pour in some zinc additive to that oil. Next time use Valvoline VR1 or the Lucas hot rod oil so you won't need an additive.
Re: Zinc additive?
[Re: JMCFAN]
#3151226
06/13/23 02:30 PM
06/13/23 02:30 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
Recent ( 1st) oil change on the roadrunner. Should I add a zinc additive? Flat tappet cam or roller ? I use Bradd Penn . I don't care for additives as I don't know enough about how the additive does mix and interact. I know people on here use it with great reviews. I also use the valvoline high zinc on flat tappet cars that I sell as it is at a better price than Bradd penn. Rumors out there that after Bradd changed hands that the oil is not the same . I researched and found out it's the same formula,different bottle. If a roller cam...any oil you want.
Re: Zinc additive?
[Re: Sniper]
#3151428
06/14/23 10:19 AM
06/14/23 10:19 AM
Posts: 8,165 Plymouth, MI
Blusmbl
Plymouth, MI
Castrol GTX Classic has high zinc, 1400 ppm, and phosphorus and is available at Walmart for reasonable cost. It's only available in 20w50 though. Another option is the Mobil 1 high mileage 15W50- it's cheap at Wal Mart, usually $26 for 5 quarts, and has enough zinc for flat tappet cams. I've been using it for a few years now. The other Mobil 1 oils don't have enough zinc, but the 15W50 does.
Re: Zinc additive?
[Re: Blusmbl]
#3151701
06/15/23 07:08 AM
06/15/23 07:08 AM
Posts: 5,649 Port Huron, Michigan
MI_Custumz
Castrol GTX Classic has high zinc, 1400 ppm, and phosphorus and is available at Walmart for reasonable cost. It's only available in 20w50 though. Another option is the Mobil 1 high mileage 15W50- it's cheap at Wal Mart, usually $26 for 5 quarts, and has enough zinc for flat tappet cams. I've been using it for a few years now. The other Mobil 1 oils don't have enough zinc, but the 15W50 does. I run Valvoline VR-1 10w30 conventional in my car. What would happen if I switched to Mobil 1? Mobil 1 is synthetic.
