Dash lights dimmer switch #3149008
06/05/23 10:29 PM
06/05/23 10:29 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
Does anybody sell the Dash lamp dimmer switch for a 70 challenger with a rallye dash? Thanks Guys.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: headlamp dimmer switch [Re: stickman] #3149121
06/06/23 01:33 PM
06/06/23 01:33 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
You mean High Beam Switch.
Nothing special about that switch. Plug was same across many years/models.
Re: headlamp dimmer switch [Re: PhillyRag] #3149150
06/06/23 03:03 PM
06/06/23 03:03 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
Sorry I am talking about the dash lights dimmer switch.
Re: headlamp dimmer switch [Re: stickman] #3149299
06/07/23 09:02 AM
06/07/23 09:02 AM
Canada
E
EW1BH27 Online content
EW1BH27  Online Content
E
Canada
Vans Auto has reproductions. I'd consider having an OEM rebuilt (member devinism does that) before buying a repop.
https://vansauto.com/product/interior-dash-dimmer-switch-70-74-e-body/
Re: headlamp dimmer switch [Re: stickman] #3149543
06/07/23 09:05 PM
06/07/23 09:05 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
They are notorious for going bad.
Surprised no one has designed/offered an improved sudo-replacement for them.
Something other then rebuilding one.
Doesn't carry much power at all.
Re: headlamp dimmer switch [Re: PhillyRag] #3150634
06/11/23 08:49 PM
06/11/23 08:49 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Once removed from the dash cluster, dash-lite dimmer control is EZ to troubleshoot.
The majority of problems are due to the rheostadt windings being dirty, after 50 years.. smile
Clean with some spray contact cleaner like Deoxit, let it dry and then very lightly coat the exposed wire windings with dia-lectric grease. Also now is a good time to make sure the contacts have enough pressure on the windings.
Since the OE dash lites are dim to begin with, one thing I have done on many Mopars is to put a short jumper wire between the rhoestadts' contacts so basically it is bypassed and the full 12V goes to the dash lites.
Just my $0.02... wink
Re: headlamp dimmer switch [Re: Sinitro] #3150650
06/11/23 09:53 PM
06/11/23 09:53 PM
New York
rarefish Offline
rarefish  Offline
New York
PM sent...
