Repro B-Body console tops any good? #3148674
06/04/23 06:55 PM
06/04/23 06:55 PM
Seattle, WA
3
375inStroke Offline OP
Special needs person
3
Seattle, WA
Need a '69 4-speed console top. Heard the repros were too flat, and didn't follow the curve of the console. Is this true, or still true? Are the Mopar Performance versions worth the extra $200?
Re: Repro B-Body console tops any good? [Re: 375inStroke] #3148916
06/05/23 03:37 PM
06/05/23 03:37 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
cant answer the question. But my ive never heard if the fit issues were ever resolved, and they still are too flat
And its my understanding they all come from same place
PG Classic
But Mike at BEA used to put them in a press and add a little curve in to make them fit.
Re: Repro B-Body console tops any good? [Re: gtx6970] #3148961
06/05/23 05:29 PM
06/05/23 05:29 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I wonder if they fit aftermarket consoles, but not OEM ? Or the other way around ?
Re: Repro B-Body console tops any good? [Re: topside] #3148995
06/05/23 08:29 PM
06/05/23 08:29 PM
Mass
charge70 Offline
charge70  Offline
Mass
My original console top plates fit Tony's repro consoles very nice.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Repro B-Body console tops any good? [Re: charge70] #3151018
06/12/23 09:28 PM
06/12/23 09:28 PM
Seattle, WA
3
3
Seattle, WA
Found this pic from OER, and you can see it's bent backwards. Now this part is around $290 from a few places, and the Mopar Performance version is $300 more, not $200.
