Big Block Dipstick Tube 69 B Body #3146435
05/23/23 05:14 PM
05/23/23 05:14 PM
Torq37 Offline OP
Torq37  Offline OP
I have a dipstick tube that I'm sure came off of a 69 383 with HP manifolds and power steering. The mounting tab on the tube attaches at the top motor mount bolt. The repop tubes for 68-69 all appear to attach at the lower motor mount bolt.
Were different tubes used on power steering cars or with some other combination of accessories? Were tubes attaching to the top bolt used on any 68-69 big block?
Re: Big Block Dipstick Tube 69 B Body [Re: Torq37] #3146793
05/25/23 12:39 PM
05/25/23 12:39 PM
moparx Offline
moparx  Offline
the tube on my 69 charger's 383 with power steering is attached to the bottom mount hole.
factory installation, never changed, and i have owned the car since 1970.
beer
Re: Big Block Dipstick Tube 69 B Body [Re: moparx] #3146853
05/25/23 10:25 PM
05/25/23 10:25 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
it was probably changed before you bought it 🤣 LMAO
Re: Big Block Dipstick Tube 69 B Body [Re: TJP] #3146935
05/26/23 02:01 PM
05/26/23 02:01 PM
moparx Offline
moparx  Offline
beer
HAHAHAHAHA !!!!!!!!!!
are you saying my car isn't "factory stock" ????? laugh2
beer
Re: Big Block Dipstick Tube 69 B Body [Re: moparx] #3148570
06/04/23 11:04 AM
06/04/23 11:04 AM
Torq37 Offline OP
Torq37  Offline OP
A belated thank you for that info. I went with an aftermarket tube knowing that the tab was in the right place, on the lower bolt. As others have mentioned the tube diameter was way oversize. After some filing and sanding I managed to get it in.
Re: Big Block Dipstick Tube 69 B Body [Re: Torq37] #3148600
06/04/23 01:49 PM
06/04/23 01:49 PM
moparx Offline
moparx  Offline
way back, direct connection said sanding on their chromed factory dip stick tube "may be required" for installation.
not saying yours is chromed, but just something DC said back in the day.
and sadly, aftermarket parts of today seem to lack the quality control process[es] necessary to insure proper fitment on their application[s].
beer
