904 Tailhousing Seal Sizes #3148543
06/04/23 08:29 AM
06/04/23 08:29 AM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Rebuilt a 904 ,1969 case.
Can't find a tailhousing seal that fits.
Bore is.2.245.
Every one keeps sending me a 2.45 diameter seal.
Did some research apparently AMC and Australian Chrysler uses a 2.245 ..904 seal.
Can't find a part number/listing at NAPA.
Anyone else run into this problem???
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 904 Tailhousing Seal Sizes [Re: 6bblFLASH] #3148552
06/04/23 09:17 AM
06/04/23 09:17 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I have 2 904 tail housings, don’t know the years. Bore is roughly 2.360. You can have it, just cover shipping if you can’t find a seal.
Re: 904 Tailhousing Seal Sizes [Re: rickraw] #3148554
06/04/23 09:31 AM
06/04/23 09:31 AM
N.E. Ohio
N.E. Ohio
Yes I found seals for your housing size listed.
Ok.
Thank you.
Hopefully it doesn't come to changing housing.
Transmission is in the car now....waiting for the seal...
Re: 904 Tailhousing Seal Sizes [Re: 6bblFLASH] #3148652
06/04/23 05:23 PM
06/04/23 05:23 PM
N.E. Ohio
N.E. Ohio
Found it on RockAuto.
69 Dart with 170 slant 6
Re: 904 Tailhousing Seal Sizes [Re: 6bblFLASH] #3148658
06/04/23 06:00 PM
06/04/23 06:00 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Seal
Re: 904 Tailhousing Seal Sizes [Re: CMcAllister] #3148671
06/04/23 06:51 PM
06/04/23 06:51 PM
N.E. Ohio
N.E. Ohio
Yep.
