8-3/4 Thrust buttons? #3147551
05/30/23 09:04 AM
05/30/23 09:04 AM
New York
rarefish Offline OP
rarefish  Offline OP
New York
The thrust buttons are missing on a 41 case center section that I have.
I do have a extra set of them, but what is the install method?
Re: 8-3/4 Thrust buttons? [Re: rarefish] #3147567
05/30/23 10:27 AM
05/30/23 10:27 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This is not intended as a WA comment but if this is what you have:
Thrust Buttons
You put the pin in one of them, put it in the differential, and then while holding it in place drive the other one in.
Re: 8-3/4 Thrust buttons? [Re: rarefish] #3147568
05/30/23 10:32 AM
05/30/23 10:32 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
With the center section still in the axle housing or out? work
Re: 8-3/4 Thrust buttons? [Re: rarefish] #3147569
05/30/23 10:46 AM
05/30/23 10:46 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
While on the subject of 8 3/4 rears....I've only used/worked on power lok/Sure grip performance 3rd members....does an "open" 8 3/4 3rd member use thrust buttons as well?
Thanks for any info/help
mikeG
Re: 8-3/4 Thrust buttons? [Re: DAYCLONA] #3147570
05/30/23 10:55 AM
05/30/23 10:55 AM
USA
rftroy Offline
rftroy  Offline
USA
mikeG
No. The shaft for the spider gears also acts to take the thrust between the two axles.
Correction: It's the shaft for the SIDE gears.
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: 8-3/4 Thrust buttons? [Re: DAYCLONA] #3147572
05/30/23 11:00 AM
05/30/23 11:00 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
mikeG
Open rear uses a thrust block held in place by the spider gear pin, just like the cone type .
Re: 8-3/4 Thrust buttons? [Re: JohnRR] #3147582
05/30/23 11:58 AM
05/30/23 11:58 AM
A727Tflite Offline
A727Tflite  Offline
Look at the provided schematic again, thrust block is called out verbally - just below the ring gear.
Re: 8-3/4 Thrust buttons? [Re: rarefish] #3147591
05/30/23 12:38 PM
05/30/23 12:38 PM
I've used black wheel bearing grease on the end of a cleaned up axle end with the thrust buttons centered on the axle ends and CAREFULLY installed them back in when they fell out removing the axles to replace outer axle grease seals wrench scope
Not easy but better than removing the third member and spilling all the gear oil out to install them work twocents
Re: 8-3/4 Thrust buttons? [Re: Cab_Burge] #3147613
05/30/23 02:23 PM
05/30/23 02:23 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
It's been a long time so please forgive my memory. But if you use the Green bearings the thrust buttons, or block, wasn't needed correct?
I am pretty sure the 8.75 I run has the axles lengthened for full spline engagement with the buttons removed.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 8-3/4 Thrust buttons? [Re: hp383] #3147618
05/30/23 02:46 PM
05/30/23 02:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Correct
Re: 8-3/4 Thrust buttons? [Re: Alaskan_TA] #3147947
06/01/23 09:10 AM
06/01/23 09:10 AM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Center section is out sitting on the bench.
Re: 8-3/4 Thrust buttons? [Re: rarefish] #3147979
06/01/23 12:57 PM
06/01/23 12:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A lot easier to put them in without having to do a disassembly with it on the bench.
Re: 8-3/4 Thrust buttons? [Re: rarefish] #3147985
06/01/23 01:18 PM
06/01/23 01:18 PM
[quote=rarefish] what is the install method?
I would and have used thick black wheel bearing grease around both sides of the buttons and in the pin hole and on the pin to make them stick in the clutch type posi units scope wrench up
If you can dimple the pin end so it swells up so it won't fall out that is the best way hammer scope up twocents
