Re: 8-3/4 Thrust buttons?
[Re: rarefish]
#3147567
05/30/23 10:27 AM
05/30/23 10:27 AM
Posts: 10,750 North Dakota
6PakBee
North Dakota
This is not intended as a WA comment but if this is what you have: Thrust ButtonsYou put the pin in one of them, put it in the differential, and then while holding it in place drive the other one in.
[Re: DAYCLONA]
#3147570
05/30/23 10:55 AM
05/30/23 10:55 AM
Posts: 704 USA
rftroy
USA
While on the subject of 8 3/4 rears....I've only used/worked on power lok/Sure grip performance 3rd members....does an "open" 8 3/4 3rd member use thrust buttons as well?
Thanks for any info/help mikeG No. The shaft for the spider gears also acts to take the thrust between the two axles. Correction: It's the shaft for the SIDE gears. Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: DAYCLONA]
#3147572
05/30/23 11:00 AM
05/30/23 11:00 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Thanks for any info/help mikeG Open rear uses a thrust block held in place by the spider gear pin, just like the cone type .
[Re: rarefish]
#3147591
05/30/23 12:38 PM
05/30/23 12:38 PM
Posts: 43,272 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3147613
05/30/23 02:23 PM
05/30/23 02:23 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
It's been a long time so please forgive my memory. But if you use the Green bearings the thrust buttons, or block, wasn't needed correct?
I am pretty sure the 8.75 I run has the axles lengthened for full spline engagement with the buttons removed.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#3147618
05/30/23 02:46 PM
05/30/23 02:46 PM
JohnRR
U.S.S.A.
Correct
[Re: Alaskan_TA]
#3147947
06/01/23 09:10 AM
06/01/23 09:10 AM
Posts: 2,253 New York
rarefish
New York
what is the install method? With the center section still in the axle housing or out? Center section is out sitting on the bench.
[Re: rarefish]
#3147979
06/01/23 12:57 PM
06/01/23 12:57 PM
JohnRR
U.S.S.A.
what is the install method? With the center section still in the axle housing or out? Center section is out sitting on the bench. A lot easier to put them in without having to do a disassembly with it on the bench.
[Re: rarefish]
#3147985
06/01/23 01:18 PM
06/01/23 01:18 PM
Cab_Burge
