Page 3 of 7 1 2 3 4 5 6 7
Re: headers glowing red at idle [Re: dart games] #3147315
05/28/23 10:32 PM
05/28/23 10:32 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
My instinct is to agree with Al and it's timing.
Idling when restricting the carb makes me wonder how it could possibly be so lean otherwise?
So, I don't know but agree with others that I would start with verifying timing mark. smile
Re: headers glowing red at idle [Re: INTMD8] #3147347
05/29/23 04:28 AM
05/29/23 04:28 AM
st.louis,mo.
dart games Offline OP
st.louis,mo.
thanks for all help.when i can take a weeks vacation off i will pull the motor and check timing.i can do it in car because where the rack is at in front of the balancer.so motor must be pulled.such a very bad let down.and more set backs.at my age of 62 i just want to go racing once more in my life
Re: headers glowing red at idle [Re: dart games] #3147351
05/29/23 06:12 AM
05/29/23 06:12 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
Originally Posted by dart games
gtx matt,so a vacuum leak would be a sign as my hand is over the primary of the carb and it stays running
That tells you it's really lean. Look for a vacuum leak. Did Dominic recently work on the carb?
America First!
Re: headers glowing red at idle [Re: Blusmbl] #3147363
05/29/23 08:45 AM
05/29/23 08:45 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Originally Posted by Blusmbl
Definitely try carb cleaner or something near the intake to head area, underside by the valley pan, and around the base of the carb.
Like others have mentioned, it’s either too lean or the timing is retarded. You’ve verified the timing mark with a piston stop so that is likely ruled out, but if it doesn’t die with your hand covering the carb it sounds like it’s getting excess air somewhere.
Whenever we have a new engine that shows signs of being lean (won't idle on idle circuit, red headers, runs like chit) I grab a can of crab cleaner and spray the intake mating area and carb base. You will know right away with the engine speed change.
Joe
Without Data, you’re just another guy with an opinion.
Re: headers glowing red at idle [Re: sr4440] #3147365
05/29/23 08:59 AM
05/29/23 08:59 AM
st.louis,mo.
st.louis,mo.
UPDATE,UPDATE.decided to pull timing cover to rule out cam timing .had to remove rack and pinion.with cam gear dot pointed down..crank key is in the 4 degree advance hole at 2 o clock,.o degree is at 4 o clock.should the crank key be pointing up when the cam dot is at bottom
Re: headers glowing red at idle [Re: dart games] #3147370
05/29/23 09:05 AM
05/29/23 09:05 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Rotate the engine 360 degrees and the cam dot will be on the top.
Joe
Re: headers glowing red at idle [Re: dart games] #3147371
05/29/23 09:06 AM
05/29/23 09:06 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
You really need to confirm the cam install with a dial gauge and a degree wheel. It's rare but stuff can be machined wrong unfortunately.
Re: headers glowing red at idle [Re: Tig] #3147373
05/29/23 09:15 AM
05/29/23 09:15 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Someone has sent you down a rabbit hole, I had an engine that the cam was retarded 2 teeth (28.8 degrees) and it idled ok but ran like poo. The fact that you add more fuel (covering the cab with your hand) and it runs, tells you, you nave an A/F issue.
Re: headers glowing red at idle [Re: sr4440] #3147385
05/29/23 09:52 AM
05/29/23 09:52 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
this right here I agree with.
And yes the key should be at 2 o clock when at TDC, and the corresponding cam timing dots line up.
Re: headers glowing red at idle [Re: B1MAXX] #3147411
05/29/23 12:14 PM
05/29/23 12:14 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Its pretty easy to check if its timing. With the engine running turn the distributor. If it runs better, headers stop glowing theres your sign. Then you can worry about the other issues. Seen it MANY times and it has always been a timing issue. You won't hurt the engine if the ignition timing get advanced to 40-or 50 degrees at idle. There is no load on the engine at idle. Id be willing to bet its off 14-20 degrees from where you think it is. But if you advance it and it gets better you have an answer, that costs nothing and takes minutes to try.
You seem to have another issue being a vacuum leak. Gonna have to be a HUGE leak to turn 8 headers red, not just a random cylinder or two. Think about it...The headers being red is 99% of the time from fuel being burned in the header rather than the chamber, they dont get that hot from a LACK of fuel
Re: headers glowing red at idle [Re: dart games] #3147424
05/29/23 12:41 PM
05/29/23 12:41 PM
I had a new Max Wedge 440 bracket motor do the same thing when breaking it in at night, enriching the idle mixture cure it shruggy scope wrenchtwocents
Re: headers glowing red at idle [Re: Cab_Burge] #3147433
05/29/23 01:43 PM
05/29/23 01:43 PM
st.louis,mo.
st.louis,mo.
maybee i went down a rabbit hole or not.having peace of mind the cam timing was done right is worth taking it apart.so at this point turn the motor so can gear dot is on top.where should bottom gear be at.then i can go back together get it running and enrich the mixture screws
Re: headers glowing red at idle [Re: dart games] #3147472
05/29/23 07:11 PM
05/29/23 07:11 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Get some close up pics of the lower timing gear. Need to see the marks
Re: headers glowing red at idle [Re: FastmOp] #3147479
05/29/23 07:29 PM
05/29/23 07:29 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
If it is 4 degrees advance, there is a different mark than the "0" degree dot. The dot on the cam and the "mark" will line up when the mark is closest to the cam, the cam dot will either be on the top or bottom, but it will be in line with the crank and cam. Like FastMOp said, need CLEAR pictures of the crank gear.
Re: headers glowing red at idle [Re: sr4440] #3147514
05/30/23 02:16 AM
05/30/23 02:16 AM
Kansas
Thelma133 Offline
Thelma133  Offline
Kansas
I AGREE COMPLETELY WITH THIS STATEMENT. ID BE THE CAM IS INSTALLED RETARDED AND THE CHARGE IS BURNING IN THE HEADER, NOT THE CHAMBER. I ADVANCED MY CAM AND THAT SOLVED MY PROBLEM.
Re: headers glowing red at idle [Re: dart games] #3147518
05/30/23 03:26 AM
05/30/23 03:26 AM
I have 12 BB Mopar Cloyes 3 bolt timing sets be marked wrong on the crankshaft keyways, they were assbackwards, the triangle marks were retarded and the rectangular marks were advanced puke whiney rant some of those crank gears were off a half a dot also puke whiney
the only way to truly know where the intake lobe centers are is to degree the cam.
Do not ASSUME anything when it comes to any and all after market race parts these days, trust but VERIFY scope wrenchup twocents
Re: headers glowing red at idle [Re: Cab_Burge] #3147525
05/30/23 06:38 AM
05/30/23 06:38 AM
st.louis,mo.
st.louis,mo.
the crank gear is a 7 way with the key in the 4a slot,so there is markings on the outside of crank gear with the settings and dots to line up.but there is a single dot at 0 that looks like the cam gear.after looking up the part number for top gear its a pro gear timning set.so i went on there website.the tr series shows a 3 bolt with a 3 way crank gear.the 4000 series shows the only one with a 9 way crank gear but a single bolt cam gear do agree with timing.i talked to thumper.he says his carbs are ready to go out of the box and no settings needed.i never did find nothing wrong with the carb and the intake gaskets is correct.i emailed pro gear see if they can send me instructions
Re: headers glowing red at idle [Re: dart games] #3147536
05/30/23 08:19 AM
05/30/23 08:19 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Ignition timing ...I know it's frustrating but if just had taken-in the good advice that you sought when you posted, you'd have known quickly as has been mentioned. This still is an opportunity to learn for many.
Re: headers glowing red at idle [Re: HardcoreB] #3147538
05/30/23 08:22 AM
05/30/23 08:22 AM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
I found this a couple years ago while looking for info on a Progear set.
Attached PDF document
Timing_Chain_9_Key.pdf (46 downloads)
Re: headers glowing red at idle [Re: varunner] #3147549
05/30/23 09:03 AM
05/30/23 09:03 AM
st.louis,mo.
st.louis,mo.
varrunner,thats what i have.its installed 4 degrees advance.but as the chain stretches it will go back to 0.i went on you tube and looked at vids.the cam timing is installed corectly.i checked the intake gasket.only thing left is thumpers carb.i pm him on facebook.he wont give me no turning advice other than is carbs is ready to run out of the box.this carb was never ran or fired
