Procedure wanted for opening up battery cable terminals #3147169
05/28/23 08:33 AM
05/28/23 08:33 AM
Macomb, MI
V
vinnyd76 Online content OP
vinnyd76  Online Content OP
V
Macomb, MI
Anyone have a good procedure/technique for opening up battery cable terminals that are slightly too tight to slide over post?
Trying to avoid tearing up the terminal or breaking off an ear.
Thank you in advance for your feedback.
Re: Procedure wanted for opening up battery cable terminals [Re: vinnyd76] #3147178
05/28/23 09:16 AM
05/28/23 09:16 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Re: Procedure wanted for opening up battery cable terminals [Re: vinnyd76] #3147196
05/28/23 10:47 AM
05/28/23 10:47 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ive used a good pair of snap ring pliers on multiple occasions
Re: Procedure wanted for opening up battery cable terminals [Re: vinnyd76] #3147207
05/28/23 11:40 AM
05/28/23 11:40 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I've always used a large diameter punch (much like a ring sizer) slide terminal onto taper and then tap, tap, tap with a rubber mallet the punch into the terminal. Doing so will set the taper to fit on the post properly.
Do a little at a time to get the right diameter.
Re: Procedure wanted for opening up battery cable terminals [Re: srt] #3147210
05/28/23 11:46 AM
05/28/23 11:46 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Battery terminal plier jaws are tapered to match the post profile.
Original battery in nice shape cables are hard to find, reproduction are not OE correct, but not cheap either. The terminal pliers can be used gentle to as not to mar the soft lead end.
I use mine a few times a year, always good to have the right tool for the job. beer
Re: Procedure wanted for opening up battery cable terminals [Re: Alaskan_TA] #3147230
05/28/23 01:00 PM
05/28/23 01:00 PM
moparx Offline
moparx  Offline
plus the terminal pliers are cheap.
just don't do like my brother did one time. he squeezed so hard, he broke the terminal at the spot the bolt goes through. he forgot to loosen the bolt enough........... laugh2 panic
beer
Re: Procedure wanted for opening up battery cable terminals [Re: 6PakBee] #3147249
05/28/23 03:04 PM
05/28/23 03:04 PM
Originally Posted by 6PakBee
iagree scope I've had a pair of them for a long time, work well, last forever scope wrench up
I've also use a wide blade screw driver to pry the ends away from each other when some fool over tighten them tsk rant shruggy
Re: Procedure wanted for opening up battery cable terminals [Re: Cab_Burge] #3147317
05/28/23 10:42 PM
05/28/23 10:42 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Been a pair of those in my tool box for many, many years!
Re: Procedure wanted for opening up battery cable terminals [Re: vinnyd76] #3147323
05/28/23 11:07 PM
05/28/23 11:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I've used a pair of craftsman internal snap ring pliers that I bought for tailshaft bearings years ago. Used them for a lot of other things over the years. ~ 20-30.0 on the bay ;)|
Re: Procedure wanted for opening up battery cable terminals [Re: TJP] #3147350
05/29/23 06:05 AM
05/29/23 06:05 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Thanks for posting that. I had a pair I misplaced and never could remember who made them. Just bought a pair from eBay. Thanks again. up
Re: Procedure wanted for opening up battery cable terminals [Re: 6PakBee] #3147414
05/29/23 12:20 PM
05/29/23 12:20 PM
5thAve Offline
5thAve  Offline
Flat head screw driver in the slot.
Of course if the clamp is in perfect shape and permanently part of the cable like it's not one of those bolt on replacements the proper tool is better to use.
Re: Procedure wanted for opening up battery cable terminals [Re: 5thAve] #3147427
05/29/23 12:49 PM
05/29/23 12:49 PM
moparx Offline
moparx  Offline
OOOOOOOOOHHHHHHHHHHHH !!!!!!!!!! i just HATE those bolt on terminal ends ! mad flame spank panic
nothing like asking for trouble using those things.
i have fixed more starting and charging issues over 50+ years stemming from the use of those things because of them getting loose at the cable connection, and "green death" growing into the cable because of them not being sealed to the cable.
did i mention i DON'T LIKE THEM ? laugh2
beer
Re: Procedure wanted for opening up battery cable terminals [Re: 6PakBee] #3147454
05/29/23 04:04 PM
05/29/23 04:04 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have used them for all kind of things over the years. Have an internal cup etc. that should, but is to snug to slide out? grab it with these wink
I also use them across the post opening rather that at the ends to prevent breaking the ears.
nothing wrong with the post pliers, just never needed them wink beer
Re: Procedure wanted for opening up battery cable terminals [Re: moparx] #3147456
05/29/23 04:11 PM
05/29/23 04:11 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
I too hate the bolt on replacement battery lugs tsk tsk tsk
