Re: Adding a USB port
[Re: BDW]
#3147140
05/27/23 10:03 PM
05/27/23 10:03 PM
Posts: 2,937 GA
roadrunninMark
GA
There is this but requires you to put a hole in something.. Link a roonie
[Re: BDW]
#3147152
05/28/23 02:52 AM
05/28/23 02:52 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Any add on will take to a haking job. Just will depend how disturb to you this haking job. Inside the console will demand to keep open the lid when in use, just like the cigar lighter adapter option You can install it on the console top plate. Get an extra if you want to keep your original safe. Otherwise, attach a bracket down the dash frame to install the USB port. This won’t get any interior part hacked. The dash frame gets several provision holes to screw in some bracket, so no extra holes are required. Bracket can be even horizontal to be hidden down the dash frame, not visible like a vertical bracket. This is a very interesting idea, but still would need to keep the ashtray open. https://www.classicchargers.com/about-classic-car-usb-chargers/You could make the same, building a container box for the usb port into the console ahstray though. The console ashtray lid is more discrete so visually don’t disturb like the dash one. Except if your chally got the rear console provision for the seatbelt storaging (earlier models), instead the ashtray. Sure the ashtray will require some haking, but can get an extra one for that.
[Re: NachoRT74]
#3147167
05/28/23 08:05 AM
05/28/23 08:05 AM
Posts: 4,727 Florida
BDW
Any add on will take to a haking job. Just will depend how disturb to you this haking job. Inside the console will demand to keep open the lid when in use, just like the cigar lighter adapter option You can install it on the console top plate. Get an extra if you want to keep your original safe. Otherwise, attach a bracket down the dash frame to install the USB port. This won’t get any interior part hacked. The dash frame gets several provision holes to screw in some bracket, so no extra holes are required. Bracket can be even horizontal to be hidden down the dash frame, not visible like a vertical bracket. This is a very interesting idea, but still would need to keep the ashtray open. https://www.classicchargers.com/about-classic-car-usb-chargers/You could make the same, building a container box for the usb port into the console ahstray though. The console ashtray lid is more discrete so visually don’t disturb like the dash one. Except if your chally got the rear console provision for the seatbelt storaging (earlier models), instead the ashtray. Sure the ashtray will require some haking, but can get an extra one for that. You touched on all the things that "bother" me. I know it’s stupid worrying about small things when the rest of the car is a beater. Ashtray needs to be open for plug-in Console lid needs to be open if it's inside ( I have trunk release button in console, but that's just, open lid/push button/close lid) Don't want to cut the top plate I had narrowed it down to 2 options, with #2 most likely, just because it's easiest 1) I have the later console with small ashtray, so maybe remove the ashtray bucket and fab a plate to mount something flush. 2) Put the power source up under dash and run USB extension cable under carpet and console that comes out by seat, then I'll have a pigtail out of sight when needed.
[Re: FurryStump]
#3147851
05/31/23 03:28 PM
05/31/23 03:28 PM
NachoRT74
Valencia, España
I would mount one pointing down on the bottom rear of the dash. Unplug the cord and it disappears. That was what I suggested with an horizontal bracket down the dash
