Re: 8 3/4 case?
[Re: SportF]
#3147070
05/27/23 02:35 PM
05/27/23 02:35 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Wouldn't a pinon break at its smallest-weakest point? AND, aren't all the yokes the same.......so what's wrong with a 741? This has been a mystery to me as much as DOT5 Good luck. Yes, the pinion stem ends are pretty much the same but most failures occur because of pinion deflection...IOW, under load, the pinion gear tries to deflect from the ring gear and tooth contact is lost leading to tooth failure. A larger pinion stem and bearing resist this deflection...the 742 (on the right below) has the best combination of stem size and bearing size to resist deflection.
Re: 8 3/4 case?
[Re: elmor353]
#3147091
05/27/23 03:59 PM
05/27/23 03:59 PM
Posts: 6,235 nowhere
Sniper
nowhere
I have used all of those cases without a problem. Even the 741, with the supposedly "small" pinion gear is bigger than a Ford nine inch. The factory used them behind some nasty engines and they held up just fine. Unless you're building a 500 horsepower or stronger motor you should be ok. All of the pinion gears are pretty much the same size where the pinion nut sits. There is a reason the factory went with a Dana behind a stick with a "nasty engine". That said, the 742 survived just fine behind the warm 413/stick combo in my 64 300 with N50's.
Re: 8 3/4 case?
[Re: John_Kunkel]
#3147165
05/28/23 07:59 AM
05/28/23 07:59 AM
Posts: 1,211 Minn
SportF
Minn
Well, I gotta say that picture clears it up for me. Great comparison, thanks for that. Once again Mr. Kunkel's expertise teaches me something.
Re: 8 3/4 case?
[Re: SportF]
#3147217
05/28/23 12:15 PM
05/28/23 12:15 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
Well, I gotta say that picture clears it up for me. Great comparison, thanks for that. Once again Mr. Kunkel's expertise teaches me something. The credit goes to Dr Diff, the photo was pirated from this article in the tech archives. There is more to the story also. Go to the tech archives sometime and start reading. That’s where these guys get lots of this stuff from. http://www.moparts.org/Tech/Archive/axle/1.html
Re: 8 3/4 case?
[Re: SportF]
#3147225
05/28/23 12:42 PM
05/28/23 12:42 PM
Posts: 29,650 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Well, I gotta say that picture clears it up for me. Great comparison, thanks for that. Once again Mr. Kunkel's expertise teaches me something. FIXED VERSION; Well, I gotta say that picture clears it up for me. Great comparison, thanks for that. Once again Dr. Diff's expertise teaches me something.
