Jerico 4 speed behind Gen 2 Hemi #3146311
05/23/23 02:20 AM
05/23/23 02:20 AM
Goat Rodeo
drago Offline OP
drago  Offline OP
Goat Rodeo
Hello gents,
I'm sure this has been covered to death here, but cant find in search.
What needs to be done to convert 727 auto behind 426 to jerico manual g/box in a 1970 challenger?
I guess it needs new tailshaft / clutch and pedals, new G/box K member and tunnel mods.
Plus a bellhousing. Does anyone make these to convert?
Thank you, much appreciated.
Re: Jerico 4 speed behind Gen 2 Hemi [Re: drago] #3146539
05/24/23 08:51 AM
05/24/23 08:51 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
You can get many of the components from Brewers http://www.brewersperformance.com/
You don't need a new K-frame.
Re: Jerico 4 speed behind Gen 2 Hemi [Re: drago] #3146543
05/24/23 09:18 AM
05/24/23 09:18 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
[b][/b]Only thing that would need modification is the opening for the shifter itself.
Uses a GM /400 style yoke.Driveshaft length as required .
Rear mount will be off as well, shouldn't be too hard to adapt/fab.
I think the Jerico is 22".
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Jerico 4 speed behind Gen 2 Hemi [Re: 6bblFLASH] #3147015
05/27/23 02:49 AM
05/27/23 02:49 AM
Goat Rodeo
drago Offline OP
drago  Offline OP
Goat Rodeo
Thank you Gentlemen.
Re: Jerico 4 speed behind Gen 2 Hemi [Re: drago] #3147040
05/27/23 11:04 AM
05/27/23 11:04 AM
Make sure your crankshaft has a pilot bushing or pilot bearing in it and it is machined deep enough for the input shaft to fit into it without bottoming out scope twocents luck
Re: Jerico 4 speed behind Gen 2 Hemi [Re: Cab_Burge] #3147064
05/27/23 01:23 PM
05/27/23 01:23 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I wanted to run a Lenco behind my Hemi. However, it just wasn't in the budget
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
